mickle026 653 Posted August 11, 2023 Author Posted August 11, 2023 (edited) I have now added Radarr and Sonarr provider keys and functionallity to the plugin as a standard id, leaving the custom ones still available. It will log the operation to file in the log directory. The link can be altered, but the Provider Id will either be Sonarr or Radarr I have not done it for episodes yet (not sure that is actually needed or what the link to an individual episode would be) Also fixed the first tvshow custom provider id @rbjtech, you should be able to remove your custom Id and use the dedicated field putting your link in the appropriate box without any other changes needed. Now there are two ways to add this functionallity Download available in first post Edited August 11, 2023 by mickle026
rbjtech 5345 Posted August 11, 2023 Posted August 11, 2023 Very nice - Let me check it out tomorrow ! I've included Episodes as you can then use the link back to the Sonarr Parent series - this is more than sufficient imo. All my links are now updated as I did it via the MediaInfo Plugin but need to check which ProviderId names you used in your changes ...
rbjtech 5345 Posted August 11, 2023 Posted August 11, 2023 Did a quick test - Initial impressions are it's working great for both Radarr and Sonarr. Remember to hit 'Save' if you change the URLs .. ask me how I know .. In your Plugin - this is a one-off action right once you press the Copy button - new titles need to be added manually or via other means such as the Schedule on the MediaInfo Plugin ? There are also a few more 'illegal' characters that need to be removed in creating the Sonarr link (' for example) - but they caught me out too, so I'll get a list together but tbh there are not many shows that are impacted by this. 1
mickle026 653 Posted August 11, 2023 Author Posted August 11, 2023 Rebuilt, re-upladed with an invalid character removal function. 1
mickle026 653 Posted August 11, 2023 Author Posted August 11, 2023 6 hours ago, rbjtech said: Did a quick test - Initial impressions are it's working great for both Radarr and Sonarr. Remember to hit 'Save' if you change the URLs .. ask me how I know .. In your Plugin - this is a one-off action right once you press the Copy button - new titles need to be added manually or via other means such as the Schedule on the MediaInfo Plugin ? There are also a few more 'illegal' characters that need to be removed in creating the Sonarr link (' for example) - but they caught me out too, so I'll get a list together but tbh there are not many shows that are impacted by this. The button loops through the media entries and creates the ids - its very fast. You can run it as many times as you like, but for automatic addition with media you would have to use a different method such as the media info plugin. 1
iPhoneMaxPro 16 Posted October 10, 2023 Posted October 10, 2023 On 8/12/2023 at 1:37 AM, mickle026 said: The button loops through the media entries and creates the ids - its very fast. You can run it as many times as you like, but for automatic addition with media you would have to use a different method such as the media info plugin. As soon as you have a moment of free time, could you fix the customer ID 1 of the TV series? because 2/3/4 work except the first one. Many thanks in advance
mickle026 653 Posted October 10, 2023 Author Posted October 10, 2023 7 minutes ago, iPhoneMaxPro said: As soon as you have a moment of free time, could you fix the customer ID 1 of the TV series? because 2/3/4 work except the first one. Many thanks in advance Sure thing, I thought I had done this, but I will recheck it as soon as I can. The version on my pc has had several updates, so I ought to post it. It's been a while since I checked this thread that I didn't realise so many people were using it. 1
mickle026 653 Posted October 10, 2023 Author Posted October 10, 2023 Try this one Provider_Ids_Extender.zip This is the one from my pc (more up to date, but still no where near finished) I cannot find anything wrong with Custom Show ID 1, so I may have already fixed it a while ago but not posted it. If it still doesnt work, be sure to let me know. 1
iPhoneMaxPro 16 Posted October 10, 2023 Posted October 10, 2023 2 hours ago, mickle026 said: Try this one Provider_Ids_Extender.zip 284.41 kB · 0 downloads This is the one from my pc (more up to date, but still no where near finished) I cannot find anything wrong with Custom Show ID 1, so I may have already fixed it a while ago but not posted it. If it still doesnt work, be sure to let me know. Thank you so much for your quick response, I just checked and I actually see everything in the TV series except custum id 1, do you see it instead?
mickle026 653 Posted October 10, 2023 Author Posted October 10, 2023 1 hour ago, iPhoneMaxPro said: Thank you so much for your quick response, I just checked and I actually see everything in the TV series except custum id 1, do you see it instead? I actually have no TV series on my test server, I will add some and test it as soon as I can to see what is wrong. 1
mickle026 653 Posted November 6, 2023 Author Posted November 6, 2023 A few extra ids added Provider_Ids_Extender (06Nov2023).zip 1 1
iPhoneMaxPro 16 Posted November 10, 2023 Posted November 10, 2023 On 11/6/2023 at 11:50 PM, mickle026 said: A few extra ids added Provider_Ids_Extender (06Nov2023).zip 285.14 kB · 1 download Thank you very much for the update, please confirm that the personalized menu in the TV shows (the first id) does not appear. 1
mickle026 653 Posted November 11, 2023 Author Posted November 11, 2023 I have found the error I will fix it soon 1
chander421 17 Posted November 28, 2023 Posted November 28, 2023 Thanks for this great plugin! I also use Letterboxd a lot, so would it be possible to add a "Copy Tmdb id's to Letterboxd Provider id's" button like Radarr? ( through the CustomId provider) knowing that Letterboxd links automatically via "https://letterboxd.com/tmdb/{0}"? Many thanks!
mickle026 653 Posted November 28, 2023 Author Posted November 28, 2023 I have put it in under its own keys in the movies tab. I have put 3 options, you can use any or all 3 I have NOT tested anything so no guarantees, I just put it in quickly Provider_Ids_Extender(28Nov2023).zip
chander421 17 Posted November 28, 2023 Posted November 28, 2023 Wow, that was fast! One million thanks for this update!
chander421 17 Posted November 28, 2023 Posted November 28, 2023 And I wouldn't want to exploit you, but would it be possible to also have a Letterboxd link for the crew (directors and actors)? Thanks!!
rsvg 18 Posted December 2, 2023 Posted December 2, 2023 (edited) Nevermind! I figured it out, I'm slow! Hey guys, sorry for the dumb question in advance. But how do I add a link using this plugin? I assumed it would be in the "edit metadata" model based on the screenshots, but I also see some XML. Do I edit a template or something? Thanks for the help Edited December 2, 2023 by rsvg
mickle026 653 Posted December 3, 2023 Author Posted December 3, 2023 (edited) On 28/11/2023 at 15:50, chander421 said: And I wouldn't want to exploit you, but would it be possible to also have a Letterboxd link for the crew (directors and actors)? Thanks!! The imdb or tmdb ids wont point to the crew so you cannot use them for that request, you need the full url https://letterboxd.com/film/poor-things-2023/crew/ try it: letterboxd.com/imdb/tt14230458/crew/ ie you need the poor-things-2023 part of the url You can already do this with a custom id of your own. Fill in the fields then enable it. Of course this is not automatic. Custom Movie Id Name: Letterboxd Crew Custom Movie Id Link: https://letterboxd.com/film{0}/crew/ So when you add this, in metadata Editor there will be a new field Letterboxd Crew Id: poor-things-2023 That would then produce this link in the GUI https://letterboxd.com/film/poor-things-2023/crew/ So in all reality maybe I should add a few more custom Id fields Edited December 3, 2023 by mickle026
rsvg 18 Posted December 3, 2023 Posted December 3, 2023 I don’t know if it’s because I’m running the beta (4.8) version of Emby but adding this plugin caused many/all of my movie pages to err. From the homepage I could no longer click a movie and view the page. Had to uninstall. Probably something I’m doing wrong but I could figure out how to use this personally.
mickle026 653 Posted December 3, 2023 Author Posted December 3, 2023 13 hours ago, rsvg said: I don’t know if it’s because I’m running the beta (4.8) version of Emby but adding this plugin caused many/all of my movie pages to err. From the homepage I could no longer click a movie and view the page. Had to uninstall. Probably something I’m doing wrong but I could figure out how to use this personally. I have no issues with it running on beta. There is nothing that should cause an error. An example of how to use custom links is in the post 2 above this one. 1
rsvg 18 Posted December 3, 2023 Posted December 3, 2023 25 minutes ago, mickle026 said: I have no issues with it running on beta. There is nothing that should cause an error. An example of how to use custom links is in the post 2 above this one. Thanks. I will review that post. I'm just not sure it's "automated" in the way I need. I was hoping for a custom link to show, in the links section titled "Review". And the URL of that link to be automatically generated, and include some form of ID of the movie/episode. I didn't want to have to go into every show and manually add the meta/link. https://example.com/{imdb}. Where imdb can really be any unique ID to the movie or episode that I can use to identify the content. Also I find the UI of the plugin itself a little buggy. Sometimes the values disappear. I see that maybe it's autosaving? When I return the values are gone.
mickle026 653 Posted December 3, 2023 Author Posted December 3, 2023 (edited) 1 hour ago, rsvg said: Thanks. I will review that post. I'm just not sure it's "automated" in the way I need. I was hoping for a custom link to show, in the links section titled "Review". And the URL of that link to be automatically generated, and include some form of ID of the movie/episode. I didn't want to have to go into every show and manually add the meta/link. https://example.com/{imdb}. Where imdb can really be any unique ID to the movie or episode that I can use to identify the content. Also I find the UI of the plugin itself a little buggy. Sometimes the values disappear. I see that maybe it's autosaving? When I return the values are gone. If you tell me where this is happening I will take a look at the code a see if I can see what's wrong. A screenshot would help. Automatically assigning IMDb or t.mdb to custom URLs is possible, I may add that. Edited December 3, 2023 by mickle026
jashwa 9 Posted December 13, 2023 Posted December 13, 2023 Howdy. It seems like there is some much needed escaping in the custom ids that can be set. A site that I want a custom id for uses a 2 leg path in the url (such as 'season1/episode1'). With the current implementation, not only does this not point to the correct path but actually breaks the item completely. Any time the page for an item where that is set Emby will say the item is no longer available. The only way to resolve is by uninstalling the plugin all together, so make sure you use some dummy episodes/movies for testing (if you get around to it).
mickle026 653 Posted December 13, 2023 Author Posted December 13, 2023 1 hour ago, jashwa said: Howdy. It seems like there is some much needed escaping in the custom ids that can be set. A site that I want a custom id for uses a 2 leg path in the url (such as 'season1/episode1'). With the current implementation, not only does this not point to the correct path but actually breaks the item completely. Any time the page for an item where that is set Emby will say the item is no longer available. The only way to resolve is by uninstalling the plugin all together, so make sure you use some dummy episodes/movies for testing (if you get around to it). It needs documenting, but emby server (not this plugin) does not allow you to use certain characters there. As you found out \ and / are two of them, others are " and '. There may be more. It simply doesn't let you use a a double barrelled name out of the box. I think it might be because of sql QUOTED_IDENTIFIER. I have not tested it but you probably have to double them, like \\ and // .. season1//episode1. for it to work. Like I said not tested it. If it screws up you'll have to rescan the item from the movie list view (without opening its detail page), replace its meatadata, to remove the custom id from the db.
