tomadick 8 Posted July 13, 2023 Posted July 13, 2023 Good evening, I have added the EPG source "http://www.xmltvepg.nl/rytecDE_Basic.xz". However, after that I can not edit the metadata of the channels, I have there only "a blue circle"... Can it be that the XZ file can not be spread reasonably - if I remove the EPG source, everything works fine.
Luke 42242 Posted July 13, 2023 Posted July 13, 2023 Hi, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks.
Luke 42242 Posted July 15, 2023 Posted July 15, 2023 You have an xml source with invalid data: 2023-07-14 11:42:33.760 Info HttpClient: GET http://www.xmltvepg.nl/x_path14_x 2023-07-14 11:42:43.148 Error Server: Error processing request *** Error Report *** Version: 4.8.0.39 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build6) (gcc version 12.2.0 (GCC) ) #64561 SMP Fri May 19 01:34:46 CST 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system Try removing this from your guide sources and then that should resolve this.
tomadick 8 Posted July 16, 2023 Author Posted July 16, 2023 Good morning, the source is valid and works in other systems, but it is just gz packed. So emby does not support gz packed XML files? This could be an interesting feature though, since just the rytec XML are all gz packed.
tomadick 8 Posted July 17, 2023 Author Posted July 17, 2023 (edited) ... not GZ, XZ http://www.xmltvepg.nl/rytecDE_Basic.xz Edited July 17, 2023 by tomadick
Luke 42242 Posted July 19, 2023 Posted July 19, 2023 On 7/17/2023 at 7:28 AM, tomadick said: ... not GZ, XZ http://www.xmltvepg.nl/rytecDE_Basic.xz Re:
