SteveFintel 30 Posted July 12, 2023 Posted July 12, 2023 I have Emby Theater set for gpu-next, enable display refresh rate switching checked and everything else set for Auto. When I play 24 fps content (or anything other than 60 fps), the refresh rate doesn't change. I'm running Windows 11 on a 10th gen Core i5 system (and Intel NUC). Here's what media info shows for this content. Log file attached. Video Title4K Dolby Vision HEVC CodecHEVC ProfileMain 10 Level150 Resolution3840x2160 Aspect Ratio16:9 InterlacedNo Framerate23.976 Bitrate16 mbps Video RangeDolbyVision Color Primariesbt2020 Color Spacebt2020nc Color Transfersmpte2084 Bit Depth10 bit Pixel Formatyuv420p10le Reference Frames1 mpv-log.txt
SteveFintel 30 Posted July 13, 2023 Author Posted July 13, 2023 Here you go. This is the media info: Video Title720p H264 CodecH264 ProfileHigh Level41 Resolution1280x548 Aspect Ratio320:137 InterlacedNo Framerate23.976 Bitrate6 mbps Color Primariesbt709 Color Spacebt709 Color Transferbt709 Bit Depth8 bit Pixel Formatyuv420p Reference Frames1 mpv-log.txt
SteveFintel 30 Posted July 19, 2023 Author Posted July 19, 2023 @generiqAny update on this? Although the various Android streaming devices support 4K HDR, they don't support TrueHD streams. My theater PC does support both, but only at lower refresh rates and if Emby Theater won't change refresh, then I'm stuck.
Guest Posted July 19, 2023 Posted July 19, 2023 19 hours ago, SteveFintel said: @generiqAny update on this? Although the various Android streaming devices support 4K HDR, they don't support TrueHD streams. My theater PC does support both, but only at lower refresh rates and if Emby Theater won't change refresh, then I'm stuck. I'm afraid this an emby developer issue. But based on what you're saying, what you're actually trying accomplish is HDR with Atmos, correct? And your receiver only supports HDR at lower refresh rates, yes? If so, you can try setting your refresh rate to 30hz. That will enable HDR and play video smoothly. At 30hz, the Theater UI might judder a little, but function correctly.
SteveFintel 30 Posted July 19, 2023 Author Posted July 19, 2023 I am trying to do HDR with Atmos. I've tried setting the refresh to 30 Hz permanently. Some programming (not just the UI) looks pretty bad at that rate. In any case, having Emby Theater change the refresh rate to match the content should work. My Firestick does that and the content looks terrific. But the Firestick doesn't support Dolby TrueHD.
rbjtech 5341 Posted July 20, 2023 Posted July 20, 2023 (edited) On 19/07/2023 at 01:06, SteveFintel said: @generiqAny update on this? Although the various Android streaming devices support 4K HDR, they don't support TrueHD streams. My theater PC does support both, but only at lower refresh rates and if Emby Theater won't change refresh, then I'm stuck. The Shield Pro supports all the HD Audio codecs - the only video codec it does not support is AV1. It also does not support HDR10+, but does support HDR10, DV5,DV7 and DV8. Refresh rates changes to 23.976 or 24 works fine. I think there may be 'some' other non-name devices that can do this - but it is the 'go-to' client if you want trouble free 4K HDR/Dolby Vision with HD Audio passthrough for a 'Cinema' type setup with an AVR. edit - this is obviously AndroidTV - but emby are forcing the Android (non TV) client hard - but the AndroidTV client still works 100% for me on all 4K high bitrate remux's (up to ~100Mbit/sec) - troublefree. Edited July 20, 2023 by rbjtech
