dylan62370 6 Posted July 12, 2023 Posted July 12, 2023 Hello, I'm having a transcoding problem, when I watch a movie in 4K, transcoding will activate You're going to tell me this is normal, except that the Emby is at home and so is the TV on which I'm watching my film. The two devices are connected via 1G Ethernet. In the TV settings I'm in 4K 140 mbps, but in the dashboard I have transcoding (4K HEVC Transcoder (H264 39 mbps)).
GrimReaper 4898 Posted July 12, 2023 Posted July 12, 2023 Have you explored SFN on your TV or server Dashboard to see reason for transcoding? You can also post ffmpeg log created for that session.
Luke 42245 Posted July 12, 2023 Posted July 12, 2023 By sfn he means the stats feature in the video player. Have you taken a look at that?
dylan62370 6 Posted July 13, 2023 Author Posted July 13, 2023 On 7/12/2023 at 6:17 PM, Luke said: By sfn he means the stats feature in the video player. Have you taken a look at that? No, not at all. I didn't know about this function.
Luke 42245 Posted July 14, 2023 Posted July 14, 2023 2 hours ago, dylan62370 said: No, not at all. I didn't know about this function. Can you try this again, check the stats feature, and let us know what it says? Thanks !
dylan62370 6 Posted July 14, 2023 Author Posted July 14, 2023 17 hours ago, Luke said: Can you try this again, check the stats feature, and let us know what it says? Thanks ! Hello, Reason: Reason for conversion: Max video bitrate reached
Luke 42245 Posted July 15, 2023 Posted July 15, 2023 6 hours ago, dylan62370 said: Hello, Reason: Reason for conversion: Max video bitrate reached Did you check the quality setting in the app? What is it set to?
dylan62370 6 Posted July 16, 2023 Author Posted July 16, 2023 Hello, I've tested it on another film for which I'm almost unable to play it on TV and at home, and on ethernet, the same applies to the Emby. Here's the movie information: Playback is in 4K 160 mb/s. The film plays on a 4K OLED LG TV purchased this year very recently.
Luke 42245 Posted July 22, 2023 Posted July 22, 2023 @dylan62370Did you check the quality setting in the app? What is it set to?
dylan62370 6 Posted August 27, 2023 Author Posted August 27, 2023 On 7/23/2023 at 12:05 AM, Luke said: @dylan62370Did you check the quality setting in the app? What is it set to? Hello, Sorry for the late return... Quality is set to 4K with bandwidth set to 160 mb/s. If I reduce it's worse because of the encoding... I don't understand why there's encoding knowing that I have a latest-generation OLED TV... And that I have plenty of bandwidth to play this type of film.
Luke 42245 Posted August 27, 2023 Posted August 27, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
