iPenguin02 5 Posted July 10, 2023 Posted July 10, 2023 Is there a way to select something other than the 3 offered 'Display Order' options in the dropdown? I named my library for Dragon Ball after the 'Sagas' order, but I can't select it within Emby. Any suggestions, other than manually?
GrimReaper 4927 Posted July 11, 2023 Posted July 11, 2023 16 minutes ago, iPenguin02 said: Is there a way to select something other than the 3 offered 'Display Order' options in the dropdown? Not currently. You can lend your support here: 1
