AtlasRedux 2 Posted July 10, 2023 Posted July 10, 2023 (edited) I'm watching Cross Game currently, and whenever there is a panning scene, lines/edges becomes distorted/blocky and flicker in and out quickly. It plays just fine when I start it up in Zoom Player with MadVR and LAV. All updated. File information (unrelated info cut): Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom) Overall bit rate mode : Variable Overall bit rate : 2 055 kb/s Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 8 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Bit rate : 1 955 kb/s Maximum bit rate : 14.0 Mb/s Width : 1 280 pixels Height : 720 pixels Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.071 Stream size : 333 MiB (95%) Writing library : x264 core 80 r1376 3feaec2 Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1955 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Codec configuration box : avcC Audio Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Bit rate mode : Variable Bit rate : 96.0 kb/s Maximum bit rate : 155 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Edited July 10, 2023 by AtlasRedux
Luke 42234 Posted July 10, 2023 Posted July 10, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Luke 42234 Posted July 10, 2023 Posted July 10, 2023 OK, I notice it is direct playing without transcoding. That means it is most likely an issue in the LG video player, and all we can really do is report it to LG. Is it only with anime, is that the common factor?
AtlasRedux 2 Posted July 10, 2023 Author Posted July 10, 2023 (edited) 8 minutes ago, Luke said: OK, I notice it is direct playing without transcoding. That means it is most likely an issue in the LG video player, and all we can really do is report it to LG. Is it only with anime, is that the common factor? I've only noticed it with anime, and only this anime in specific. I've watched quite a lot of "normal" and anime content, and this is the first time I've noticed this weird artificating. It's in every panning scene as well, so it gets annoying. Edited July 10, 2023 by AtlasRedux 1
