z3ndra 7 Posted July 9, 2023 Posted July 9, 2023 hello I have a problem, here I have a disk mounted remotely on a dedicated server, this one is well detected by emby (it was before), and since just now without any reason I find myself with an error that no streams are available. I specify that I had to empty the temp transcoding folder because it was getting full. I do not understand that it does not find a stream knowing that it manages to browse the folder to the content, it is clearly visible on the network. the content directly stored on the server, on the other hand, is well read. thanks in advance
Luke 42245 Posted July 10, 2023 Posted July 10, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
z3ndra 7 Posted July 10, 2023 Author Posted July 10, 2023 this problem appear near 23'50 / 23"59 ffmpeg-transcode-1966daa6-9b89-42a8-8577-58ec7caa28a7_1.txt hardware_detection-63824547666.txt embyserver-63824461200.txt
Luke 42245 Posted July 10, 2023 Posted July 10, 2023 Did you see this in the ffmpeg log? 08:29:00.768 /home/desktop/Moovix/1fichier/films/Knights.of.the.Zodiac.2023.MULTi.VFF.1080p.AMZN.WEB-DL.DDP5.1.H264-FCK.Wawacity.foo.mkv: Permission denied Have you taken a look at this?
