tamasmx 2 Posted July 8, 2023 Posted July 8, 2023 Hi all I'm not sure if this behavior has always been like this. It seems as if server administrators' accounts cannot be modified their lists of devices from which they can be accessed. For example, the account "lovolde" is non-admin, its device list can be configured (this is okay) Then there's "Tamara" where i cannot set which devices it can log in. Apparently i cannot log in with new devices. Am i missing something or is it a bug? Tamas
Solution Luke 42241 Posted July 8, 2023 Solution Posted July 8, 2023 HI, correct. You can't restrict device access from admins. It's a safeguard to avoid allowing you to lock yourself out of your own server.
tamasmx 2 Posted July 8, 2023 Author Posted July 8, 2023 20 minutes ago, Luke said: HI, correct. You can't restrict device access from admins. It's a safeguard to avoid allowing you to lock yourself out of your own server. Thanks, that makes sense. My login issue was due to the fact that I missed the https (last character) in the protocol of the url. 1
