lonewolf1996 2 Posted July 8, 2023 Posted July 8, 2023 I have been having problems with Emby Theater. I can't seem to figure it out. There is no sound. I don't mean just audio. There's no sound when your going through the screen either. I'v tried uninstalling and reinstalling Theater. Changed audio settings then back to default, Iv restarted the server, reinstalled the server. The server is running on a terramaster. It was just working fine. I went to the next video and then no sound. Everything works fine in the web app and on everything else. I tested it on my smart tv and cell. Its all working fine, Just not in emby theater. embyserver.txt
Luke 42237 Posted July 8, 2023 Posted July 8, 2023 Hi, how have you configured audio settings in the app? Can we please see an example of what you're trying to play?
lonewolf1996 2 Posted July 8, 2023 Author Posted July 8, 2023 (edited) Thanks for the reply and the help. Here's the picture of the stats of the video I was trying to play. And it doesn't matter what I try to play, Its all the same. No sound at all. I also posted the audio settings of emby. Edited July 8, 2023 by lonewolf1996 forgot something
Luke 42237 Posted July 8, 2023 Posted July 8, 2023 Are you sure the sound in the app isn't muted? Can you show the audio settings from inside the app? Thanks.
lonewolf1996 2 Posted July 8, 2023 Author Posted July 8, 2023 yes its not muted. I already checked. I watched one video and then tried to watch another but now s no sound. I tried everything I could think of.
lonewolf1996 2 Posted July 9, 2023 Author Posted July 9, 2023 Well. I found something out. I downloaded the 3.0.19 version. Which when downloaded is just the folder with emby. If I run Emby through there then theres sound. I don't understand it. But maybe it would help solving the problem. Its only when I install emby theater than theres no sound. Any ideas why. I downloaded it from here https://github.com/MediaBrowser/emby-theater-windows/releases
Luke 42237 Posted July 10, 2023 Posted July 10, 2023 That's strange. The only difference is a slightly newer mpv build.
lonewolf1996 2 Posted July 10, 2023 Author Posted July 10, 2023 I know. I still haven't figured it out.
Guest Posted July 11, 2023 Posted July 11, 2023 On 7/7/2023 at 9:52 PM, lonewolf1996 said: There's no sound when your going through the screen either. If by this you mean the UI sounds also don't output, then this isn't an mpv issue. It suggests an electron issue
lonewolf1996 2 Posted July 11, 2023 Author Posted July 11, 2023 I forgot about Electron. But it still doesn't explain why there's no sound if I install it, and then its normal if I run it from the downloaded folder.
Guest Posted July 11, 2023 Posted July 11, 2023 1 hour ago, lonewolf1996 said: I forgot about Electron. But it still doesn't explain why there's no sound if I install it, and then its normal if I run it from the downloaded folder. I'm suggesting there's a glitch in the current Theater build, with regards to electron functionality. Are you confirming that there are also no UI sounds? No sound coming from the app at all, and not only when playing media?
lonewolf1996 2 Posted July 13, 2023 Author Posted July 13, 2023 (edited) Yes that's right. There's no UI sound, and no audio when playing a video. Doesn't matter what video. Edited July 13, 2023 by lonewolf1996
lonewolf1996 2 Posted July 25, 2023 Author Posted July 25, 2023 Any ideas. I'm still having the same problem.
Luke 42237 Posted August 3, 2023 Posted August 3, 2023 On 7/13/2023 at 12:47 PM, lonewolf1996 said: Yes that's right. There's no UI sound, and no audio when playing a video. Doesn't matter what video. Do you have UI sounds enabled in the app settings?
lonewolf1996 2 Posted August 3, 2023 Author Posted August 3, 2023 Yes I do. I was going to send you a screenshot but I'm not home at the moment. 1
Solution Luke 42237 Posted August 3, 2023 Solution Posted August 3, 2023 Also have you checked this? https://pureinfotech.com/adjust-app-sound-windows-10/
lonewolf1996 2 Posted August 5, 2023 Author Posted August 5, 2023 Im trying that now. It seemed to work for a couple of seconds. But than back to no sounds. If it helps when the sound worked there was still no UI sounds
lonewolf1996 2 Posted August 5, 2023 Author Posted August 5, 2023 I think I found the problem. I have been using a program called FXsound to help boost the sound quality. out of Curiosity, I uninstalled it and reset the sound from the page that you sent me. I then reinstalled Emby Theater and tried it. Everything seems to be working. I don't understand why FXsound would interfere. I've been using that for years. So I will leave it uninstalled for now. Thank you for all your help. Let me know if you have any other Ideas as to why. 1
