zha93 1 Posted July 6, 2023 Posted July 6, 2023 Hey - I've got a new VM running Ubuntu 22.04 (proxmox is the host if that matters), I can see the passthru gpu show up in lspci and emby seems to detect everything just fine under the transcoding config section. However when a stream starts that requires transcoding it falls back to software. I don't see any errors in the transcode log (I'm most likely missing the errors) If someone would take a look, I'd really appreciate it. Thank you- embyserver (1).txt ffmpeg-transcode-eb15fb55-313b-4424-a7f4-363a756984a0_1.txt
zha93 1 Posted July 6, 2023 Author Posted July 6, 2023 If it helps any... I installed emby 4.8.0.39 just now and it works! I'd rather not run beta code if there is a fix for 4.7. Thank you.
Luke 42245 Posted July 6, 2023 Posted July 6, 2023 Hi, 4.8 is probably the fix as it has updated hardware acceleration support.
zha93 1 Posted July 6, 2023 Author Posted July 6, 2023 Gotcha. Hopefully GA code will be sometime "Soon" I had stumbled across another thread where 4.8 fixed a similar issue. Thanks for responding. 1
