ReadySalted 9 Posted July 5, 2023 Posted July 5, 2023 (edited) Hi, I recently started using a couple of new mpv config files to improve performance and change the UI. When I use Emby Theater I see both the Theatre UI and the standalone at the same time. Is there any way to avoid that? To be clear, I would like to only see the Emby UI when using Emby because I think it's better. Also attached the script for the modded UI. modernx.lua Edited July 5, 2023 by ReadySalted
Luke 42237 Posted July 5, 2023 Posted July 5, 2023 Hi, yea that must be coming from mpv because that’s not an Emby ui.
ReadySalted 9 Posted October 30, 2023 Author Posted October 30, 2023 It took ages for me to get around to doing this but what I needed was to clear out my custom stuff from %appdata%/mpv and place things in a folder called portable_config beside the mpv.exe so that I only get this UI when using mpv outside of emby. 1
