Rainey 2 Posted October 27, 2014 Posted October 27, 2014 (edited) As stated in title, if i download a new cover with MBS metadata edit image it deletes the folder.jpg file and replaces it with a poster.jpg file. I have been using folder.jpg for years and many other program also use it, even MBS uses it when it is there. Is there any way to make MBS not change the file to poster and use the folder.jpg name instead. Edited October 27, 2014 by Rainey
swhitmore 781 Posted October 27, 2014 Posted October 27, 2014 Can you check what metadata saver you're using?
Rainey 2 Posted October 27, 2014 Author Posted October 27, 2014 (edited) I have the XBMC.nfo box checked. I just add my movies to the library and wanted it to read the .xml files first but also save the nfo files. Once i get all movies add i may switch back to .xml saver. I just added about 2000 movies of two types, but they all show up under movies even though i added two location names, only in folders are they seperated. So i now need to figuire out how to tags them in groups or i will just have to use folder view all the time. As i got another group of about 900 to add still. Edited October 27, 2014 by Rainey
swhitmore 781 Posted October 27, 2014 Posted October 27, 2014 I have the XBMC.nfo box checked That'll do it. Use the MediaBrowser format unless you're using XBMC.
Luke 42184 Posted October 27, 2014 Posted October 27, 2014 the metadata file formats have nothing to do with the image file names. the file names we are using are designed to be the most compatible with the largest number of apps. if you really prefer folder over poster the only way to solve that will be through additional configuration
Rainey 2 Posted October 27, 2014 Author Posted October 27, 2014 Thanks Luke It is not a big problem, i can always make a bat file that copies the poster.jpg to folder.jpg to have both. Change them all in seconds. I have also a .jpg file with the same names as the movie file for backup as i have had problems in the past with program deleting, hiding, resizing the folder.jpg file so i learned my lesson long ago.
