jordy 284 Posted September 18, 2023 Author Posted September 18, 2023 @Luke, Unfortunately it seems that it's still not recording two channel the same time. I scheduled one channel to record straight away and then set a second channel to commence recording as the 1st show finished. My recording settings are 5mins before program start and 10mins after it ends. As you can see from the SS's, Emby schedules both shows (both shows listed in the Active Recordings tab) and commences recording the 1st one instantly but the 2nd one does not actually start the recording process - see the Folder listings and LiveTV_Recordings tab (both SS taken at 12:27pm, 2mins after the 2nd show should have started to record) SS and Log attached embyserver(3).txt
Solution Luke 42242 Posted September 18, 2023 Solution Posted September 18, 2023 OK the way the fix was done might require you to remove the tuner device(s) from live tv setup and then add them back. Are you able to do that?
jordy 284 Posted September 19, 2023 Author Posted September 19, 2023 (edited) 6 hours ago, Luke said: OK the way the fix was done might require you to remove the tuner device(s) from live tv setup and then add them back. Are you able to do that? yes I can give that a try. Will let you know. EDIT: We have a WINNER. Works perfectly! Thanks Jordy Edited September 19, 2023 by jordy update 1
Luke 42242 Posted September 19, 2023 Posted September 19, 2023 Thanks. I'll see if the fix can be improved to apply to existing tuners. 1
