Natetronn 8 Posted July 1, 2023 Posted July 1, 2023 I'm running into an issue where extras don't show up with multi-disc. If I remove one of the discs and rescan the library the extras show up fine (in what appears to the be the same spot the 2nd disc was previously in.) But if I put the 2nd disc back, the extras disappear again. Is there something I need to set in order to have both multi-disc and extras work from within the same folder? Or is it one of the other when it comes to multi-disc?
Abobader 3485 Posted July 1, 2023 Posted July 1, 2023 Hello Natetronn, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Natetronn 8 Posted July 1, 2023 Author Posted July 1, 2023 (edited) 31 minutes ago, Luke said: Hi there, how are your files named and organized? Hi Luke, thanks for the reply! I followed the guidelines here: https://emby.media/support/articles/Movie-Naming.html Here is an example of a two disc movie with extras (I'd prefer to designate the extras with -disc1 and -disc2 (or maybe just Disc 1, Disc 2), since that's where they actually came from, but I set them as below, since I didn't know if that was causing an issue.) Lord of the Rings - Fellowship of the Ring ├── extras │ ├── Lord of the Rings - Fellowship of the Ring-extras01.mkv │ └── Lord of the Rings - Fellowship of the Ring-extras02.mkv ├── Lord of the Rings - Fellowship of the Ring-disc1.mkv └── Lord of the Rings - Fellowship of the Ring-disc2.mkv Note: at one point I also tried folder/names with colons (:), since the titles of these movies actually include colons, but I removed them in case they were causing issue and instead used the dashes. Edited July 1, 2023 by Natetronn
Solution Natetronn 8 Posted July 1, 2023 Author Solution Posted July 1, 2023 (edited) I seem to have it working with the following: L/The Lord of the Rings - Fellowship of the Ring ├── extras │ ├── The Lord of the Rings - Fellowship of the Ring - Extras - extended edition 1.mkv │ └── The Lord of the Rings - Fellowship of the Ring - Extras - extended edition 2.mkv ├── The Lord of the Rings - Fellowship of the Ring - extended edition-disc1.mkv └── The Lord of the Rings - Fellowship of the Ring - extended edition-disc2.mkv Edited July 1, 2023 by Natetronn 1
