glowplug 1 Posted June 29, 2023 Posted June 29, 2023 When using the iPad app, the media filename and path are displayed under Media Info. However, in the web app however this media file info is not available. Is there any way to display this info when using the web app (or maybe a hidden option I need to enable)? thanks
GrimReaper 4896 Posted June 29, 2023 Posted June 29, 2023 Which server version? As path should be displayed in the Media Info section at the bottom of any item Detail view.
glowplug 1 Posted June 29, 2023 Author Posted June 29, 2023 ah, it's an old version I'll update, good to know that it's there! thank you 1
