DrumMaster777 2 Posted June 28, 2023 Posted June 28, 2023 (edited) I can't connect to my media server. Is there a recent update that caused a global issue or is an update being worked on? I already know about fixing this when it occurs and what to check for & I'm at the point where it's just not working at all. I've yet to try smashing it to pieces but am about to. I've restarted the server several times, I've rebuilt the entire library from scratch, I even made sure that the external drive with all my content is labeled correctly (D: in File Explorer, in Emby), there's no reason why it shouldn't work simply after restarting it. embyserver.txt hardware_detection-63823545894.txt Edited June 28, 2023 by ebr Removed image with sensitive content
Luke 42290 Posted June 28, 2023 Posted June 28, 2023 Hi, there is no issue that we’re aware of. Did you change any Emby server network settings?
DrumMaster777 2 Posted June 28, 2023 Author Posted June 28, 2023 Edit - Issue Resolved. I ended up biting the bullet & restarting my router plus also removing & re-adding my network name from my FireStick from where I watch emby. Its up and running now, I just lost all my playlists. This can be closed, thank you 1
