hawaiizfynest 0 Posted June 28, 2023 Posted June 28, 2023 I have a QNAP NAS and it has emby installed. I already have the ports forwarded so that its accessible via WAN address, i already have a domain on godaddy for it, i just cant figure out how to get this forwarded to my domain. Also, when i update the app on QNAP, it wants me to delete the app and reinstall, will that mess up my config and if so, any tips on what i should do for updates?
Abobader 3485 Posted June 28, 2023 Posted June 28, 2023 Hello hawaiizfynest, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42185 Posted June 28, 2023 Posted June 28, 2023 Hi, do you mean how to point your godaddy domain to your ip address? Quote Also, when i update the app on QNAP, it wants me to delete the app and reinstall, will that mess up my config and if so, any tips on what i should do for updates? Should be OK, but can you show a screenshot of this? Thanks.
hawaiizfynest 0 Posted June 28, 2023 Author Posted June 28, 2023 14 hours ago, Luke said: Hi, do you mean how to point your godaddy domain to your ip address? Should be OK, but can you show a screenshot of this? Thanks. yes, do i just make an A record on the domain and add my WAN ip there? what else is needed if so?
justinrh 263 Posted June 28, 2023 Posted June 28, 2023 (edited) Go into DNS management for your domain, create an A record and add your IP address for it. If you want a sub-domain, create a CNAME record and add your hostname, then the domain+period. Edited June 28, 2023 by justinrh
