revelator1969 1 Posted June 27, 2023 Posted June 27, 2023 I just downloaded a couple of HD and UHD lip sync test videos to try on my gaming pc. It seems the audio is lagging slightly and i cant fix this as my receiver only allows you to delay audio not to advance it. Its been like this for a while but today i was able to prove my suspicions of the audio lagging. Im using win 11 and Theatre 3.0.20. My gaming pc is high spec so there is not any performance issues. I also get it when using the Samsung tv app. Its direct playing from a usb hard drive on the gaming pc. Do you guys have any idea how to fix this? thanks Rob
Luke 42237 Posted July 1, 2023 Posted July 1, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! 1
revelator1969 1 Posted July 8, 2023 Author Posted July 8, 2023 On 01/07/2023 at 20:25, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Thanks for your reply. I think it was something to do wit my set up, i have managed to figure it out and things are as they should be. Thanks again. 1
