bcqingfeng 3 Posted June 27, 2023 Posted June 27, 2023 (edited) I installed kodi-20.1-Nexus-arm64-v8a and kodi nextgen v8.2.8 on a S905 tv box but it failed to playback ISO and BDMV movies. Tried to debug on a win10 PC with Kodi 19.5 and kodi nextgen v8.2.8. The same thing happens. Tried: for ISO: 1. kodi 19.5 with embynexgen 8.2.8, play ISO, failed; 2. kodi 19.5 with embynexgen 8.2.8, play MKV, successed; 3. emby theater 3.0.15 for win, play ISO, partly successed (can play but stays at the menu,need to drag the progress bar); 4. emby 3.2.32 for android phone, play ISO, partly successed (can play but stays at the menu,need to drag the progress bar); 5. emby v2.0.83 for android TV , play ISO, partly successed (can play but stays at the menu,need to drag the progress bar); 6. kodi 19.5, add video source with webdav mounted, play ISO, successed. for BDMV: 7. emby theater 3.0.15 for win, play BDMV, successed --image3 8. kodi 19.5 with embynexgen 8.2.8, play BDMV, failed --image1 9. kodi 19.5, add video source with webdav mounted, play BDMV (index.bdmv), successed; --image2 the logs of 1, 2, 3, 6, 7, 8, 9 are copied to attached log txt. (sorry for possible inconvenience, please let me know if need to be seprated files) Looks like the nexgen add-on is getting native path from server when play ISO and BDMV, while the emby native apps get the right path. How can i figure this? LOGS.txt Edited June 27, 2023 by bcqingfeng
bcqingfeng 3 Posted June 27, 2023 Author Posted June 27, 2023 Emby Server on synology NAS, Version: 4.8.0.32
quickmic 1709 Posted June 29, 2023 Posted June 29, 2023 I only reviewed the log, no tests performed yet, but question: Is this path correct and accessible by Kodi? Have you mounted the drive? 2023-06-27 10:25:07.367 T:20904 INFO <general>: VideoPlayer::OpenFile: /volume2/mnt/CloudDrive/189cloud/mount/189BD/鬼子来了 (2000)/Devils.on.the.Doorstep.2000.DVD.480i.MPEG-2.Dolby.Digital.5.1.ISO 2023-06-27 10:25:07.369 T:29152 INFO <general>: Creating InputStream 2023-06-27 10:25:07.369 T:29152 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting /volume2/mnt/CloudDrive/189cloud/mount/189BD/鬼子来了 (2000)/ 2023-06-27 10:25:07.391 T:29152 ERROR <general>: Skipped 1 duplicate messages.. -> "/volume2/mnt/CloudDrive/189cloud/mount/189BD/鬼子来了 (2000)/Devils.on.the.Doorstep.2000.DVD.480i.MPEG-2.Dolby.Digital.5.1.ISO"
quickmic 1709 Posted June 29, 2023 Posted June 29, 2023 2 minutes ago, quickmic said: I only reviewed the log, no tests performed yet, but question: Is this path correct and accessible by Kodi? Have you mounted the drive? 2023-06-27 10:25:07.367 T:20904 INFO <general>: VideoPlayer::OpenFile: /volume2/mnt/CloudDrive/189cloud/mount/189BD/鬼子来了 (2000)/Devils.on.the.Doorstep.2000.DVD.480i.MPEG-2.Dolby.Digital.5.1.ISO 2023-06-27 10:25:07.369 T:29152 INFO <general>: Creating InputStream 2023-06-27 10:25:07.369 T:29152 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting /volume2/mnt/CloudDrive/189cloud/mount/189BD/鬼子来了 (2000)/ 2023-06-27 10:25:07.391 T:29152 ERROR <general>: Skipped 1 duplicate messages.. -> "/volume2/mnt/CloudDrive/189cloud/mount/189BD/鬼子来了 (2000)/Devils.on.the.Doorstep.2000.DVD.480i.MPEG-2.Dolby.Digital.5.1.ISO" Can you please also perform a test on a Windows PC with. Maybe you Box is not capable to open the file. (I had that on some devices). 2023-06-27 10:25:34.368 T:32036 WARNING <general>: could not find codec parameters for Z:\mnt\CloudDrive\189cloud\mount\189BD\鬼子来了 (2000)\Devils.on.the.Doorstep.2000.DVD.480i.MPEG-2.Dolby.Digital.5.1.ISO
bcqingfeng 3 Posted June 29, 2023 Author Posted June 29, 2023 1 hour ago, quickmic said: Can you please also perform a test on a Windows PC with. Maybe you Box is not capable to open the file. (I had that on some devices). 2023-06-27 10:25:34.368 T:32036 WARNING <general>: could not find codec parameters for Z:\mnt\CloudDrive\189cloud\mount\189BD\鬼子来了 (2000)\Devils.on.the.Doorstep.2000.DVD.480i.MPEG-2.Dolby.Digital.5.1.ISO Hi Quickmic, thanks for your reply! For the first point you mentioned "Is this path correct and accessible by Kodi? Have you mounted the drive?" The answer is NO. As mentioned I think this is the exact problem, Kodi with emby nexgen addon is getting the streaming path from server for MKV, so that is a success. but for ISO and BDMV the server gave direct file path ,which is not mounted on KODI, so the playback failed. Further more, I dont think this path can be mounted on KODI since it is on the server's host. Supplementary: Never set "Shared network folder" in the emby library; emby nexgen works under default addon mode. Interestingly for "native" EMBY apps, they are getting correct path for ISO and BDMV. For the test on windows PC, yes, all the tests except 4 and 5 are performed on win10 PC (Kodi 19.5 with embynexgen; emby theater). (test 4 and 5 were performed on android phone and TV, not so easy to get the log and they act the same as in PC, so i did not include the logs.) The codec warning you noticed is not a problem, it went on playing smoothly. Please tell me if i am missing something.
quickmic 1709 Posted July 2, 2023 Posted July 2, 2023 Quote For the first point you mentioned "Is this path correct and accessible by Kodi? Have you mounted the drive?" The answer is NO. As mentioned I think this is the exact problem, Kodi with emby nexgen addon is getting the streaming path from server for MKV, so that is a success. but for ISO and BDMV the server gave direct file path ,which is not mounted on KODI, so the playback failed. Further more, I dont think this path can be mounted on KODI since it is on the server's host. Well yes, Kodi plugin uses native access to filesystem when playing ISO or bdmv. In the past, Emby server was not capable to play such content directly. Seems the situation has changed @Luke Currently you need native access for the plugin but I'll review if improvement is possible.
bcqingfeng 3 Posted July 3, 2023 Author Posted July 3, 2023 22 hours ago, quickmic said: Well yes, Kodi plugin uses native access to filesystem when playing ISO or bdmv. In the past, Emby server was not capable to play such content directly. Seems the situation has changed @Luke Currently you need native access for the plugin but I'll review if improvement is possible. Thanks for your explanation! Do you mean reset the plugin to native access mode instead of addon mode?
quickmic 1709 Posted July 3, 2023 Posted July 3, 2023 (edited) 55 minutes ago, bcqingfeng said: Thanks for your explanation! Do you mean reset the plugin to native access mode instead of addon mode? No, you can keep addon mode. Addon mode automatically falls back to native mode when playing iso, but it needs file access. Edited July 3, 2023 by quickmic
bcqingfeng 3 Posted July 4, 2023 Author Posted July 4, 2023 22 hours ago, quickmic said: No, you can keep addon mode. Addon mode automatically falls back to native mode when playing iso, but it needs file access. thanks! so i need to fill file address at the emby library "Shared network folder", and make that accessible to KOI, like "nfs://192.168.0.108/volume2/mnt/CloudDrive/189cloud/mount/189BD", right?
Solution quickmic 1709 Posted July 4, 2023 Solution Posted July 4, 2023 (edited) 6 minutes ago, bcqingfeng said: thanks! so i need to fill file address at the emby library "Shared network folder", and make that accessible to KOI, like "nfs://192.168.0.108/volume2/mnt/CloudDrive/189cloud/mount/189BD", right? Depends, but probably yes. Native access configuration is highly dependent on your network specifications. E.g. I use native mode on OS level bases means the os itself mounts the drives. Anyway that's my config and seems not to be an option for your setup (Emby server on Windows). You need to set "Shared network folder" on nfs:// or smb:// on Emby server side. Also Kodi needs that folder to be mounted (credentials). -> Testting via Kodi's filebrowser, it needs access to the mounts. Edited July 4, 2023 by quickmic
quickmic 1709 Posted July 4, 2023 Posted July 4, 2023 (edited) Edit: I think the smb prefix is not even neccessary. only "\\192.168.0.205\storage2\emby-test\subtitle2-smb4" as shared path. (at least for smb) Edited July 4, 2023 by quickmic
