flic 13 Posted June 25, 2023 Posted June 25, 2023 Have you noticed the missing functionalities between the web interface and Emby Theater? Here are a few I noticed: 1- App Settings, Server, Live TV, +Add TV Source, M3U shows nothing. In a web browser it shows a TV Source Setup page 2- In Home Screen, when hovering any thumb nails, it does not show the green Play arrow as the web interface does That would be great if you could fix Theater to make it behave as the web interface Thanks
flic 13 Posted June 25, 2023 Author Posted June 25, 2023 (edited) 3.0.20 Server on UnRaid: 4.7.13.0 Edited June 25, 2023 by flic
Luke 42237 Posted June 25, 2023 Posted June 25, 2023 These functions are all in theater. But if your primary input method is a mouse then it sounds like you want to switch out of tv display mode in the app settings. then you’ll get the play button on hover.
flic 13 Posted June 25, 2023 Author Posted June 25, 2023 both are set to Auto, so the web defaults to Desktop where hovering works Theater defaults to TV where hovering does not work
Luke 42237 Posted June 25, 2023 Posted June 25, 2023 20 minutes ago, flic said: both are set to Auto, so the web defaults to Desktop where hovering works Theater defaults to TV where hovering does not work Right well you don’t typically see that kind of hovering behavior in a TV app. Glad you figured it out.
flic 13 Posted June 29, 2023 Author Posted June 29, 2023 here's the issues with Display set as Desktop (on my 4K monitor): -The desktop shows too many thumbnails. Even if I set them bigger, the "More like this" section is still displayed. That causes powering on my standby mechanical HDs (some Movies and TV series are on "sleeping" hard drives). I havent seen an option to turn that section off... Last annoyance-Thumbnails are very small. Even if I set them bigger, it looks a bit like TV mode but they become too big if I exit full screen An option to turn off "More like this" section would be appreciated Thanks again for considering Luke 1
