austie 4 Posted June 22, 2023 Posted June 22, 2023 I have recently added a series that according to IMDB has an unknown episode section. I've tried setting it as season 0 as the folder and tried to get the correct info that way but it shows as Season 1 & the first 6 episodes. Hoping I could use the Identify button for the season found no option to do this and in the episode folder metadata only have a TVDB reference where I can't find a reference for this batch. Its shorts for "Star Wars Young Jedi Adventures" that came out before the season did but can't get it to display correctly? Has anyone else had this sort of problem before?
Solution GrimReaper 4845 Posted June 22, 2023 Solution Posted June 22, 2023 If I understood correctly, you're referring to this: https://m.imdb.com/title/tt20674124/episodes/?season=-1 Those are the same episodes listed as Specials for Star Wars: Young Jedi Adventures (ID 420658) on TVDB: https://thetvdb.com/series/star-wars-young-jedi-adventures/seasons/official/0 Nane your episodes accordingly (S00Exx), put them in Season 0 and rescan.
Luke 42185 Posted June 22, 2023 Posted June 22, 2023 @austieplease let us know if this helps. Thanks.
austie 4 Posted June 23, 2023 Author Posted June 23, 2023 @GrimReaperThanks that helped, originally I had it in it's on group not the main group given how it was showing on IMDB 1
