SSJ4Gokou 2 Posted June 22, 2023 Posted June 22, 2023 So, I am having this issue where I moved all my shared folders from Volume 1 to Volume 3. Now I am trying to install Emby which it does install, but then is manually stopped. Then when I try to start the service manually I get an error saying that it failed to run the package service. I click on run a second time and it runs then manually stops. I have copied all the files from EmbyServer over to the new volume but unable to get Emby up and running.
Luke 42242 Posted June 22, 2023 Posted June 22, 2023 hi, is any emby server log file generated? Emby Server Data Folder
SSJ4Gokou 2 Posted June 22, 2023 Author Posted June 22, 2023 This topic can be closed. I ended up installing through docker. Thanks! 1
SSJ4Gokou 2 Posted June 30, 2023 Author Posted June 30, 2023 I hate to bring this back up. I was running into issues with the rocker version, mainly slow transcoding, so I thought I would try the native Synology app. To answer your question @Lukeno, there is no logs being generated
SSJ4Gokou 2 Posted June 30, 2023 Author Posted June 30, 2023 Update: so instead of installing this to volume 3 I went ahead and installed it on volume 2 which is an m.2 storage. For whatever reason this worked and emby is up and running. I don't know why but I am going to leave it as is for now. 1
