Misinthe 46 Posted June 20, 2023 Posted June 20, 2023 Hello everyone, like the title says, it just started happening that we're watching a show and suddenly the playback gets stuck and when it resumes, the audio gets out of sync, here are the logs of it while it's playing and after it's stopped. Thank you! Logs When Stopped.txt Logs While Playing.txt
Misinthe 46 Posted June 23, 2023 Author Posted June 23, 2023 23 hours ago, Luke said: Hi, this is direct playing on Samsung? Yes sir, playing on the native app for Samsung TV in my livingroom.
Misinthe 46 Posted June 24, 2023 Author Posted June 24, 2023 On 22/06/2023 at 13:44, Luke said: Hi, this is direct playing on Samsung? It does this and then it gets all out of wack. It seems to only be happening in my Samsung TV, it plays fine on the LG.
justinrh 263 Posted June 25, 2023 Posted June 25, 2023 Have you verified the network connection is stable?
Solution Misinthe 46 Posted June 25, 2023 Author Solution Posted June 25, 2023 4 hours ago, justinrh said: Have you verified the network connection is stable? I did, after many tests I decided to give up and reload the files into the server, that seems to have fixed the issue for now. 1
