corion 2 Posted June 20, 2023 Posted June 20, 2023 bonjour, y a-t-il un moyen pour remplacer un genre donné (par exemple "Comedy") par un autre ("Comédie") sur un ensemble de titres ? j'ai regardé du côté du Gestionnaire de métadonnées, mais on peut saisir un mot-clef sur un répertoire, mais pas de Genre ... du coup je ne vois pas trop à quoi sert ce gestionnaire ; dans le même contexte, il serait intéressant de saisir le Genre d'après une liste des genres (ceux déjà entrés par exemple), ça éviterait les erreurs de saisie et serait moins fastidieux.
ebr 16332 Posted June 20, 2023 Posted June 20, 2023 Hi. Check out the Genre Cleaner plug-in in the catalog.
corion 2 Posted June 20, 2023 Author Posted June 20, 2023 well, it doesn't work , may be I don't know how to use it ; I want to replace all the "Hooror" genre by "Horreur" , so in Genre Cleaner I create "Horror" genre, and I map it to "Horreur" ; I save and I start library scan ; but "Horror" keeps on appearing ! even after a few minutes ; where is my mistake ?
Luke 42239 Posted June 20, 2023 Posted June 20, 2023 1 hour ago, corion said: well, it doesn't work , may be I don't know how to use it ; I want to replace all the "Hooror" genre by "Horreur" , so in Genre Cleaner I create "Horror" genre, and I map it to "Horreur" ; I save and I start library scan ; but "Horror" keeps on appearing ! even after a few minutes ; where is my mistake ? HI, please provide a specific example. Thanks.
corion 2 Posted June 20, 2023 Author Posted June 20, 2023 my previous example is not clear ? not easy to translate my untidy mind in english ... so, let's try an other way : could you explain me how Genre Cleaner works ?
ebr 16332 Posted June 21, 2023 Posted June 21, 2023 20 hours ago, corion said: and I start library scan Hi. You would need to refresh metadata, not just scan the library.
corion 2 Posted June 21, 2023 Author Posted June 21, 2023 it works once this morning, most of the undesired genres have been replaced, but I don't know excactly how I've made it !! only one genre "crime" is remaining, and after a lot of tests this afternoon, including the scan of the library, the refresh of metadatas and refresh of files, in different orders, the genre remains ... tomorrow I will edit each movy to replace this genre ; each movie stands now in its own directory, with its artworks and nfo file ; big job, but I think it's almost perfect ! 1
