troth 0 Posted June 20, 2023 Posted June 20, 2023 Hopefully, someone can help me im not smart enough to figure it out. Basically with the emby app or with the emby app for kodi for android playback randomly fails for unknown reasons some apps say web socket connection error sometimes it just stops and its super annoying. If you need a different log or anything else I can post I dont think its a transcode problem because it just seems to happen locally and everything is direct stream. embyserver-63822729600.txt
Luke 42245 Posted June 20, 2023 Posted June 20, 2023 Hi, where exactly do you see this? web socket connections have nothing to do with playback. It's normal for them to get closed after a while.
troth 0 Posted June 20, 2023 Author Posted June 20, 2023 1 hour ago, Luke said: Hi, where exactly do you see this? web socket connections have nothing to do with playback. It's normal for them to get closed after a while. It pops up on the screen after playback stops
ebr 16337 Posted June 20, 2023 Posted June 20, 2023 Hi. Are you sure network communications aren't dropping completely? The websocket message could just be an additional symptom due to all network comms dropping. Is this a wired connection? Server on local LAN?
troth 0 Posted June 20, 2023 Author Posted June 20, 2023 9 hours ago, ebr said: Hi. Are you sure network communications aren't dropping completely? The websocket message could just be an additional symptom due to all network comms dropping. Is this a wired connection? Server on local LAN? Its a local server. The client is connected to wifi and I thought that might be the problem also so I ran a wired connection to it and it still does it. All the other clients dont seem to have this problem either its just the tv.
ebr 16337 Posted June 20, 2023 Posted June 20, 2023 It definitely sounds like a network interruption. If you are seeing this with the Android TV app, the next time it happens please follow the instructions to send a log from the app Thanks.
troth 0 Posted June 21, 2023 Author Posted June 21, 2023 Alright I got the relevant log. https://paste.kodi.tv/ihawosapuv
ebr 16337 Posted June 21, 2023 Posted June 21, 2023 11 hours ago, troth said: Alright I got the relevant log. https://paste.kodi.tv/ihawosapuv Hi. That's a Kodi log with which I'm not very familiar but I definitely see evidence of losing the connection to the server. error <general>: EMBY.emby.http: [ ServerUnreachable ]
