DanBarnard 0 Posted June 19, 2023 Posted June 19, 2023 Hi gurus. Bit of advice please. I've been using emby for a fair few years but never used it really outside my home network. If I try to connect from an external IP the app finds my server, but shows me the internal IP(192.168....) If I click "sign in with emby connect" it just sends me in a loop back to the same page. If I connect manually and pop in my external IP address and default port number it works a treat. The problem is I don't always know my home IP address when I'm away, and I thought the idea of emby connect was that it would automatically find your sever just by logging in. What am I missing here?
GrimReaper 4894 Posted June 19, 2023 Posted June 19, 2023 Have you linked your local user with respective Connect account?
DanBarnard 0 Posted June 19, 2023 Author Posted June 19, 2023 I think so. I've added my emby connect email address to the local user account
GrimReaper 4894 Posted June 19, 2023 Posted June 19, 2023 Just now, DanBarnard said: I think so. I've added my emby connect email address to the local user account And have you confirmed link in received confirmation email?
DanBarnard 0 Posted June 19, 2023 Author Posted June 19, 2023 Doesn't give an option to send an email. I go to server settings, and under user I have created my self a user and it's asks for an emby connect email address. This says it will link the server to my account. Hit save. And that's it. I don't get an email saying I need to confirm or anything. I'm obviously missing something simple.here but it's a real head scratcher
DanBarnard 0 Posted June 19, 2023 Author Posted June 19, 2023 Update. I created a new emby connect account with another email address..added this email to my local user account and it's exactly the same. It finds my server but as a local IP address... I'm not on the local network so it won't connect. Is there an option to get it to show the remote IP here instead?-
GrimReaper 4894 Posted June 19, 2023 Posted June 19, 2023 1 hour ago, DanBarnard said: Doesn't give an option to send an email. I go to server settings, and under user I have created my self a user and it's asks for an emby connect email address. This says it will link the server to my account. Hit save. And that's it. I don't get an email saying I need to confirm or anything. There's no option, it should be done automatically. There are some topics every now and then about users not receiving confirmation email upon linking - and for some it was in Spam folder. It'd look like:
GrimReaper 4894 Posted June 19, 2023 Posted June 19, 2023 1 hour ago, DanBarnard said: Update. I created a new emby connect account with another email address..added this email to my local user account and it's exactly the same. It finds my server but as a local IP address... I'm not on the local network so it won't connect. Likely because of the same reason - you haven't confirmed link on the second email either.
DanBarnard 0 Posted June 19, 2023 Author Posted June 19, 2023 I checked.my.emails.and I had the email from emby..I've clicked and confirmed. Situation still the same. From both android device and windows pc
Luke 42238 Posted June 19, 2023 Posted June 19, 2023 10 hours ago, DanBarnard said: I think so. I've added my emby connect email address to the local user account Can you try redoing this process by removing and reapplying it?
