alvinfly 2 Posted June 19, 2023 Posted June 19, 2023 I'm playing without video transcoding, source file is a webdl, h.264 mkv file. my server is Debian, using latest emby-server. tried restarting server, nothing works symptom: suddenly stop after a few minutes, showing stopped, if click start, it wont start, has to exit and enter again. this issue has been on and off for a long time, at first it only happens when the source file bitrate is high, so i stopped downloading bluray and only downlaod webdl, sometimes upgrading would fix the problem. it is source specific, meaning it would only happen to certain source file. embyserver.txt
Luke 42245 Posted June 19, 2023 Posted June 19, 2023 Hi, please attach the ffmpeg log as well. Thanks.
alvinfly 2 Posted June 19, 2023 Author Posted June 19, 2023 1 hour ago, Luke said: Hi, please attach the ffmpeg log as well. Thanks. Hi, attached is the new log, I restarted emby then started playing, so less unrelevant logs embyserver.txt ffmpeg-remux-46b1ed95-bdeb-4b62-a3ec-be86f413d7bc_1.txt hardware_detection-63822791183.txt
Luke 42245 Posted July 2, 2023 Posted July 2, 2023 @alvinflythis is likely your issue: If you re-enable that, then the server will be able to transcode the video and reduce the bitrate for a remote connection, which can often help with issues such as this.
