Carlo 4561 Posted June 29, 2023 Posted June 29, 2023 Can you post one of these episodes up in dropbox, Google Drive or other place and send me the link? I'd like to try and duplicate your results. Carlo
nospotify 187 Posted June 29, 2023 Author Posted June 29, 2023 @CarloWe did that earlier, and also did a multi hour screen share session. You have had several thoughtful hypotheses that we tested and which turned out not to be the issue. If this is happening with scores and scores of different files, and it occurs only when Emby is streaming to the CCHD, the issue isn't with the files.
ebr 16352 Posted June 30, 2023 Posted June 30, 2023 17 hours ago, wordlover said: it occurs only when Emby is streaming to the CCHD, the issue isn't with the files Hi. I think we already established that the core issue is in the files. You are seeing the "symptom" of this only happening when casting to that particular device but that is not the actual cause. I believe the cause is that, when casting to that device, we are running the item through ffmpeg and, in that case, with the bad timings in the file, direct seeking does not work. We may be able to work around this issue and will look into that but the core issue is bad data in the files.
nospotify 187 Posted June 30, 2023 Author Posted June 30, 2023 @ebrAs @Carlorequested (above) I ran an example file through MKVToolNix, which found no bad data, and the cleaned output file had the same problems. Direct link to file sent to him, and now to you, via DM.
Carlo 4561 Posted June 30, 2023 Posted June 30, 2023 On 6/29/2023 at 3:33 PM, wordlover said: @CarloWe did that earlier, and also did a multi hour screen share session. You have had several thoughtful hypotheses that we tested and which turned out not to be the issue. If this is happening with scores and scores of different files, and it occurs only when Emby is streaming to the CCHD, the issue isn't with the files. Yes I remember as we tried it a couple different ideas to rule everything out or find an issue. Using the same players when connected to my system you couldn't duplicate the issue as my files direct played, but even when I turned down the bitrate on the server to force transcoding it still worked fine, except for the jump ahead which requires the transcoder to catch up process that section before the client has media to display. No way around that, and it's like this on every client that transcodes. That was why I thought it was a media issue back then as well. What I wanted to find out here is why the different playbacks on the two devices What I did want to verify is the same outcome using your file. Depending on the nature of what I see it may be easy to script running it across your libraries.
nospotify 187 Posted July 11, 2023 Author Posted July 11, 2023 So is this an accurate summary of the situation @ebr, @Luke, @Carlo? 1. Chromecast HD doesn't support the full range of audio codecs that the old Chromecast does. 2. Because of this video files with audio in such formats needs to be transcoded when casting to CCHD. 3. The version of FFmpeg that EMby relies on throws errors when transcoding audio on any files with even tiny timing imperfections. 4. Emby devs now know what to modify in your code (or FFmpeg?) so that this transcoding isn't so exacting and thus playback controls will work properly when casting to CCHD from now on?
ebr 16352 Posted July 11, 2023 Posted July 11, 2023 12 hours ago, wordlover said: Chromecast HD doesn't support the full range of audio codecs that the old Chromecast does Is that true? You have a reference? 12 hours ago, wordlover said: Emby devs now know what to modify in your code If the above is true, then, no we don't.
nospotify 187 Posted July 11, 2023 Author Posted July 11, 2023 (edited) I thought that is what @Carlolooked up (or @visproduction?) In a different thread about this problem. If that isn't the case, then why is Emby transcoding when casting to CCHD and not when casting to older CCs? That seems to be what is causing the problem. Edited July 11, 2023 by wordlover
Luke 42285 Posted July 12, 2023 Posted July 12, 2023 15 hours ago, wordlover said: I thought that is what @Carlolooked up (or @visproduction?) In a different thread about this problem. If that isn't the case, then why is Emby transcoding when casting to CCHD and not when casting to older CCs? That seems to be what is causing the problem. Because that's what it's telling us is supported. To my knowledge, Chromecast doesn't support any ac3 or eac3 decoding. so it can only pass it through to something that can decode it. So it depends on what it's connected to that will determine what audio formats are supported or not.
nospotify 187 Posted July 12, 2023 Author Posted July 12, 2023 Could you three Emby devs PLEASE confer directly?! This confirms what Carlo or Vis indicated re: new CCHD not handling full range of audio codecs, which for some reason ebr is still questioning. This process is maddening. And ebr said above "I believe the cause is that, when casting to that device, we are running the item through ffmpeg and, in that case, with the bad timings in the file, direct seeking does not work. We may be able to work around this issue and will look into that but the core issue is bad data in the files." This asynchronous process of different devs chiming in at different times and apparently not reading the earlier parts of these threads has been going on for months and months and months. It is now clear what the problem is. Can y'all fix it?!
ebr 16352 Posted July 12, 2023 Posted July 12, 2023 Hi. When I said we may be able to work around the issue it was if the case was that we were simply incorrectly determining the audio support. I'm not sure that is the case and it is looking increasingly likely that it isn't. Can you confirm that both of your CC devices are connected to the exact same equipment for your tests?
nospotify 187 Posted July 12, 2023 Author Posted July 12, 2023 Yes - the setups are absolutely identical. The only variable is which CC device Emby is casting to. One sample of hundreds of video files that have the same playback control problem only on CCHD, as well as numerous logs, have been posted above and in other threads and DM'd.
ebr 16352 Posted July 12, 2023 Posted July 12, 2023 7 hours ago, wordlover said: the setups are absolutely identical Meaning it actually is two different setups? Or you are taking one TV setup and switching devices between the two ChromeCasts on the exact same port on the exact same TV setup?
nospotify 187 Posted July 12, 2023 Author Posted July 12, 2023 Sorry for not being clearer. As I have posted before, it's one setup - either Samsung tablet or Pixel 5a phone running Emby app, casting to original CC in HDMI 1 on Samsung TV, then uncasting, and then casting to CCHD in HDMI 2 port. I have tested every variable: have tried reversing the order (first casting to CCHD then Old CC), have tried reversing theb HDMI ports they're plugged into, have tried removing Old CC from system entirely, etc. etc. etc. etc.
ebr 16352 Posted July 12, 2023 Posted July 12, 2023 Okay, thanks for the re-confirmation. And this is the exact device that has the problem (the HD version)? https://www.amazon.com/Chromecast-Google-TV-Streaming-Entertainment/dp/B0B9HS6DLZ
nospotify 187 Posted July 12, 2023 Author Posted July 12, 2023 Yep, that's the device, CCHDwGTV (not 4k).
ebr 16352 Posted July 13, 2023 Posted July 13, 2023 I apologize if we've been through this and I've just missed it or forgotten but have you tried disabling the permission for audio transcoding for this user and then playing the problem item? This would just be a test to confirm that the device actually can play the audio in question.
nospotify 187 Posted July 13, 2023 Author Posted July 13, 2023 (edited) 11 minutes ago, ebr said: I apologize if we've been through this and I've just missed it or forgotten but have you tried disabling the permission for audio transcoding for this user and then playing the problem item? This would just be a test to confirm that the device actually can play the audio in question. Where is that setting? I see overall transcoding options, but none just for audio. Edited July 13, 2023 by wordlover
nospotify 187 Posted July 13, 2023 Author Posted July 13, 2023 6 minutes ago, ebr said: Uncheck the audio one. BOOM! There it is. Fixed. Or at least the standard video file I uploaded for you to test is now playable and controllable here. Apparently the audio transcoding that Emby is doing - but only when casting to CCHD and not to the old CC - is what's causing the playback control problem. Why Emby is trying to transcode audio, only when casting to CCHD, is a separate question I gladly leave to you, in hopes that no other files I try to play will require audio transcoding. (I tested a few others now, too, and all are played and controlled fine.)
nospotify 187 Posted July 13, 2023 Author Posted July 13, 2023 3 minutes ago, Luke said: Does the file have more than one audio track? It does not - single "English AAC audio" track.
nospotify 187 Posted July 13, 2023 Author Posted July 13, 2023 As Carlo noted upthread: "EAC-3 AC-3 is supported on the CC Google TV device but we're not sending this audio codec to ffmpeg as a choice. Part of the problem here besides files with dozens of subs and files with bad timings is that we're doing audio transcoding and remuxing when we shouldn't have to."
Luke 42285 Posted July 13, 2023 Posted July 13, 2023 21 minutes ago, wordlover said: It does not - single "English AAC audio" track. Are you sure? How many channels is the track?
nospotify 187 Posted July 13, 2023 Author Posted July 13, 2023 I am not a tech person - just looking at Emby's screen for each episode, which doesn't show a drop down to select other audio tracks, unlike for other video files. Is there someplace else I should be looking? Did you download the sample file I put on Dropbox a while ago?
