softworkz 5133 Posted September 14, 2023 Posted September 14, 2023 14 minutes ago, softworkz said: But then it still returns tons of "Invalid timestamps" errors, Generally, ffmpeg works fine with separate streams - there's neither an issue with ffmpeg nor with Emby. You can try this for example: ffmpeg -allowed_extensions ALL -protocol_whitelist "file,http,https,tcp,tls" -i https://devstreaming-cdn.apple.com/videos/streaming/examples/img_bipbop_adv_example_ts/master.m3u8 -c copy -y tmp.mkv
dgrenier 1 Posted September 15, 2023 Author Posted September 15, 2023 Thanks for the response, It's interesting, if I test with this m3u8 manifest: Quote ffmpeg -allowed_extensions ALL -protocol_whitelist "file,http,https,tcp,tls" -i https://pe-fa-lp03a.9c9media.com/live/NOOVO/p/hls/00000201/716cf4c845225692/manifest.m3u8 -c copy -y tmp.mkv The mkv file is only audio (apologies for the French if you do try it lol) I just wish it could work like it does with VLC
softworkz 5133 Posted September 15, 2023 Posted September 15, 2023 16 minutes ago, dgrenier said: Thanks for the response, It's interesting, if I test with this m3u8 manifest: The mkv file is only audio (apologies for the French if you do try it lol) I just wish it could work like it does with VLC With VLC I don't get audio as well. I can only recommend to contact the provider of those streams.
dgrenier 1 Posted September 18, 2023 Author Posted September 18, 2023 On 14/09/2023 at 22:20, softworkz said: With VLC I don't get audio as well. I can only recommend to contact the provider of those streams. Oh really? I have audio in VLC 3.0.19 on Fedora on: https://pe-fa-lp03a.9c9media.com/live/NOOVO/p/hls/00000201/716cf4c845225692/manifest.m3u8, but if nothing can be done I understand, like I said before its not even for me, it's for a friend who wanted to record a show on my server, so thanks for trying, cheers 1
