terryrusselo 0 Posted June 17, 2023 Posted June 17, 2023 (edited) my buddy is having issues playing HDR content on his LG TV it used to work fine. his kid watches Encanto almost daily. used to play fine. now it plays "very dark", other HDR movies same thing. only his TV. LG app. transcode log included for Venom. same issue. color is correct, but everything is DARK. HDR content on YouTube and Netflix play fine. Transcoding handled by 2070 super, works fine on my non HDR android devices over LTE. movies are NOT DolbyVison ANDY-ffmpeg-transcode-e355be32-a2aa-4a2b-8115-b7c987115d58_1.txt Edited June 17, 2023 by terryrusselo
Luke 42234 Posted June 17, 2023 Posted June 17, 2023 Hi, that’s odd. Can you provide an example log for the same video when it does succeed? 1
terryrusselo 0 Posted June 17, 2023 Author Posted June 17, 2023 (edited) here are 2 : one is direct play from local win 10 machine, emby theatre, hdr monitor 2nd is android app, note 10plus HDR, lowered bitrate transcode, over LTE DIRECT-THEATRE-LOCAL-ffmpeg-transcode-d5eaf8c2-261e-44fb-9178-73e172d1dad2_1.txt ANDROID-LTE-HDR-Note10+-ffmpeg-transcode-f3739723-d191-4696-b0b4-7b22348b2fb6_1.txt Edited June 17, 2023 by terryrusselo
terryrusselo 0 Posted June 17, 2023 Author Posted June 17, 2023 also i double checked both encanto and venom have not updated the video files since January. sometimes my server upgrades movies... sometimes the upgrade sucks. not the case this time.
trusselo 225 Posted June 17, 2023 Posted June 17, 2023 oops i was logged in under my dads account. its me!
SamES 1084 Posted June 17, 2023 Posted June 17, 2023 You have a bitrate limit set which is causing it to transcode, this may be causing you to lose HDR. Did you always have the bitrate set at this rate, or was it previously higher? What happens if you increase the limit above 12-15Mb/sec?
trusselo 225 Posted June 19, 2023 Posted June 19, 2023 (edited) On 16/06/2023 at 23:32, SamES said: You have a bitrate limit set which is causing it to transcode, this may be causing you to lose HDR. Did you always have the bitrate set at this rate, or was it previously higher? What happens if you increase the limit above 12-15Mb/sec? this TV is at a friends house, i dont have fiber. yes it always has a limit set outside of home network. My 2070 super transcodes HDR just fine on all other tested devices, with and without bitrate limit set, inside and outside the home network. Edited June 19, 2023 by trusselo
SamES 1084 Posted June 20, 2023 Posted June 20, 2023 (edited) On 17/06/2023 at 11:35, terryrusselo said: here are 2 : one is direct play from local win 10 machine, emby theatre, hdr monitor 2nd is android app, note 10plus HDR, lowered bitrate transcode, over LTE DIRECT-THEATRE-LOCAL-ffmpeg-transcode-d5eaf8c2-261e-44fb-9178-73e172d1dad2_1.txt 1.02 MB · 0 downloads ANDROID-LTE-HDR-Note10+-ffmpeg-transcode-f3739723-d191-4696-b0b4-7b22348b2fb6_1.txt 88.09 kB · 0 downloads How do you know these are preserving HDR after transcoding? The Android-LTE log looks like it failed 19:32:48.531 [hevc @ 0x14aad00] decoder->cvdl->cuvidCreateDecoder(&decoder->decoder, params) failed -> CUDA_ERROR_OUT_OF_MEMORY: out of memory 19:32:48.531 [hevc @ 0x14aad00] Failed setup for format cuda: hwaccel initialisation returned error. 19:32:48.780 Impossible to convert between the formats supported by the filter 'graph 0 video input from stream 0:0' and the filter 'auto_scale_0' 19:32:48.781 Error reinitializing filters! 19:32:48.781 Failed to inject frame into filter network: Function not implemented 19:32:48.781 Error while processing the decoded data for stream #0:0 19:32:48.852 Conversion failed! 19:32:48.852 Direct-Theatre-Local is done in SW, not HW transcoding - and it looks like a significant drop in size >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason Automatic software decoder >> False False Software Codec VideoInput >> False False Not a hardware decoder Scaling >> False False VideoOutput >> False False Not a hardware encoder x264 Software Encoder >> False False Software Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> - yuv420p yuv420p 3840x2076 >> scale scale >> - yuv420p yuv420p 640x346 >> Edited June 20, 2023 by SamES
trusselo 225 Posted July 10, 2023 Posted July 10, 2023 The latest LG emby update fixed the issue thank you very much. 1
