Masterz 2 Posted June 15, 2023 Posted June 15, 2023 Device: Nokia Streaming Box 8010. Media file: Tom.Clancys.Jack.Ryan.S03E01.rus.LostFilm.TV Just black screen when try to playback. No any ffmpeg-* files created around that time, so attaching only embyserver.txt embyserver.txt
Masterz 2 Posted June 15, 2023 Author Posted June 15, 2023 (edited) 55 minutes ago, Luke said: Hi, what Emby app are you trying to play with? 2023-06-15 13:11:38.770 Info SessionManager: Playback start reported by app AndroidTv 2.0.83g playing Tom.Clancys.Jack.Ryan.S03E01.rus.LostFilm.TV. Started at 0 ms Edited June 15, 2023 by Masterz
ebr 16307 Posted June 15, 2023 Posted June 15, 2023 Hi. Is this item DolbyVision or HDR and, if so, does the device support that?
Masterz 2 Posted June 15, 2023 Author Posted June 15, 2023 1 hour ago, ebr said: Hi. Is this item DolbyVision or HDR and, if so, does the device support that? Not sure, IMHO not. VLC player play it w/out issues.
ebr 16307 Posted June 16, 2023 Posted June 16, 2023 Oh, it is an AVI/Xvid file. It probably needs to transcode. Try using the "Playback Correction" option on the menu during playback.
Masterz 2 Posted June 16, 2023 Author Posted June 16, 2023 3 hours ago, ebr said: Oh, it is an AVI/Xvid file. It probably needs to transcode. Try using the "Playback Correction" option on the menu during playback. Just tried, see in log starting from 19:00. Still no video, now appears errors about transcode files named *graph.txtffmpeg-transcode-f496f0b9-5492-4d80-bacc-1267f50c7b1b_1.txtffmpeg-transcode-0fc99102-de9e-455e-a977-2bca221c42e8_1.txtffmpeg-transcode-08d21093-c652-4a9b-b60e-5409b5399c5d_1.txtffmpeg-transcode-a79c2041-9c45-4ecc-8fa3-cd6fadd79703_1.txtembyserver.txtffmpeg-transcode-329942a5-f9ee-4c32-97e7-278331fcc6c9_1.txt
Masterz 2 Posted June 17, 2023 Author Posted June 17, 2023 Same file playback on Emby for Android Mobile 3.3.07 & Emby Theater 3.0.19 - fine. On AndroidTv 2.0.83g - not starting. Playback Correction - no effect. Emby Web 4.7.13.0 - not starting. See no Playback Correction. All tries in log. No ffmpeg-* files created/left. embyserver.txt
ebr 16307 Posted June 17, 2023 Posted June 17, 2023 It may be a bad source. I'm wondering how you have a recent item that is encoded in such an archaic format. How was it created?
Masterz 2 Posted June 17, 2023 Author Posted June 17, 2023 8 minutes ago, ebr said: It may be a bad source. I'm wondering how you have a recent item that is encoded in such an archaic format. How was it created? Not sure. If so (archaic format) - can close the issue, no worry. Thanx for Your support.
Masterz 2 Posted June 18, 2023 Author Posted June 18, 2023 Just checked couple of recently downloaded videos. All of them have video codec XVid from build 50 to 73. At least for this is commonly used codec. Have one series, where video playback stops on ~30 minutes time, audio continues while video freeze. Then audio reach EOF and remaining video starts in silence. First & Second episode demonstrate same behavior. Will check others.
Masterz 2 Posted June 18, 2023 Author Posted June 18, 2023 (edited) 2 hours ago, Masterz said: Just checked couple of recently downloaded videos. All of them have video codec XVid from build 50 to 73. At least for this is commonly used codec. Have one series, where video playback stops on ~30 minutes time, audio continues while video freeze. Then audio reach EOF and remaining video starts in silence. First & Second episode demonstrate same behavior. Will check others. When switching from audio AC 5.1 to AC stereo (second track) playback interrupted at different point in time - on minute ~35. Noticed: when only audio sounds - progress bar on player not moving, but moving later - during video with no audio playback. Edited June 18, 2023 by Masterz
ebr 16307 Posted June 18, 2023 Posted June 18, 2023 Where are these coming from? There is no reason anything new should be created with those formats.
Masterz 2 Posted July 1, 2023 Author Posted July 1, 2023 Starting playback of same file from same Emby server on 4 devices. All demonstrate Direct Play for Video & Audio streams: Three fit in screen, Chrome demonstrate same. Theater & AndroidTv - playback Ok. Android - freeze on one frame; Chrome on black screen - then both throw "No compatible streams..." message. Emby log attached. Media info: Previously had some issue with MKV playback on Xbox - on rare cases. Starting this summer this is disaster reg. AVI files - like a quarter cases fails to playback on various devices. IMHO old/archaic/well-known/... codec must be supported well. embyserver.txt
Masterz 2 Posted July 1, 2023 Author Posted July 1, 2023 Just connected back Xbox One. As before - issues with some MKV sources, but plays all AVI files, which are not playable on Android & AndroidTv. Looks cause not in Emby server, but in players software. P.S. Sadly. Was bought AndroidTv to save some money on electricity, but it usage very limited for me.
Luke 42185 Posted July 3, 2023 Posted July 3, 2023 @Masterz Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
ebr 16307 Posted July 3, 2023 Posted July 3, 2023 He said above that Android TV worked fine and it was the standard app that failed in this instance... On 7/1/2023 at 1:16 AM, Masterz said: Theater & AndroidTv - playback Ok. Android - freeze on one frame; Chrome on black screen - then both throw "No compatible streams..." message. My guess is it is one of those AVI files that needs to transcode.
Luke 42185 Posted July 3, 2023 Posted July 3, 2023 Can you provide a sample video for testing? Thanks.
Masterz 2 Posted July 4, 2023 Author Posted July 4, 2023 11 hours ago, Luke said: Can you provide a sample video for testing? Thanks. Two of previously noted file shared here: https://drive.google.com/drive/folders/1ORHd6Rv-uydrtoqAX_pmFN_CLt4eXkg_?usp=drive_link
Luke 42185 Posted July 10, 2023 Posted July 10, 2023 On 7/3/2023 at 12:03 AM, Luke said: @Masterz Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Can you try downloading the latest version of this (3.3.15), and see if it's able to play now? thanks.
