warrentc3 47 Posted June 13, 2023 Posted June 13, 2023 When attempting to modify a series recording, the loading circle is there indefinitely and "Channels", "Air days", and typically "Air time" never populate with the current values.
Luke 42185 Posted June 13, 2023 Posted June 13, 2023 Hi there, please attach the emby server log from when the problem occurred. Thanks.
warrentc3 47 Posted June 14, 2023 Author Posted June 14, 2023 log attached. i repro'd this on my test box, where there were no recordings scheduled... scheduled one... then attempted to edit the series... same behavior. embyserver (4).zip
Luke 42185 Posted June 14, 2023 Posted June 14, 2023 OK we'll take a look at it. Thanks for reporting.
warrentc3 47 Posted June 14, 2023 Author Posted June 14, 2023 24 minutes ago, Luke said: OK we'll take a look at it. Thanks for reporting. Thank you! If i get a chance, I'll play with some indexes to see if there's an improvement. 1
warrentc3 47 Posted June 30, 2023 Author Posted June 30, 2023 Can confirm that this issue happens even with emby guide data plugin
