gavinusme 1 Posted June 9, 2023 Posted June 9, 2023 Basically I want to create some brief sound demos from my favourite movie action scenes. I can split my MKV files easily enough, but all the programs I have used output all the sound as stereo and/or my denon amp determines the sound of the split file as only mutli channel NOT the original which was Dolby atmos, DTS X etc. Does anybody know a program that can split my movie files but still keep the original sound?? thanks for your time and patience g
Abobader 3485 Posted June 9, 2023 Posted June 9, 2023 Hello gavinusme, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2023 Posted June 9, 2023 Posted June 9, 2023 How did you split the files? I would expect MKVToolNix to do it OK (but I don't have experience of that audio type). Paul 1
rbjtech 5335 Posted June 9, 2023 Posted June 9, 2023 (edited) 2 hours ago, gavinusme said: Basically I want to create some brief sound demos from my favourite movie action scenes. I can split my MKV files easily enough, but all the programs I have used output all the sound as stereo and/or my denon amp determines the sound of the split file as only mutli channel NOT the original which was Dolby atmos, DTS X etc. Does anybody know a program that can split my movie files but still keep the original sound?? thanks for your time and patience g If mkvtoolnix (mkvmerge) fails - then I would try ffmpeg -ss = start time -t = duration .thd = truehd (with Atmos) .dts = dts-hd ma (incl X) .eac3 = Dolby Digital Plus (incl JOC Atmos) ffmpeg -i "input.mkv" -ss 1:30 -t 30 -c:a copy "audio.thd" mediainfo says they still have object data following a brief test - but I have not tested this. ffmpeg -i "input.mkv" -ss 1:30 -t 30 -map 0:2 -c:a copy "audio.dts" above example uses the 2nd Audio track (DTS-HD:MA-X) Edited June 9, 2023 by rbjtech
Thidsa 44 Posted June 9, 2023 Posted June 9, 2023 Mkvtoolnix works. Does not change the audio, just cut the file no matter which audio
gavinusme 1 Posted June 9, 2023 Author Posted June 9, 2023 thankyou so much will try this solutions today fingers crossed
Solution gavinusme 1 Posted June 10, 2023 Author Solution Posted June 10, 2023 thanks so much everybody!! A program called handbrake worked, changing the audio to TrueHD passthru kept dolby atmos, yay!! 1
rbjtech 5335 Posted June 10, 2023 Posted June 10, 2023 5 hours ago, gavinusme said: thanks so much everybody!! A program called handbrake worked, changing the audio to TrueHD passthru kept dolby atmos, yay!! I believe handbrake is effectively a GUI for ffmpeg under the hood - Passthru is effectively a copy - so all good
gavinusme 1 Posted June 15, 2023 Author Posted June 15, 2023 Does anybody know what I have to put into handbrake to get an exact video copy of a mkv video?? thanks in advance
rbjtech 5335 Posted June 15, 2023 Posted June 15, 2023 3 minutes ago, gavinusme said: Does anybody know what I have to put into handbrake to get an exact video copy of a mkv video?? thanks in advance Are you wanting to modify the Audio tracks but keep the video track original ? Handbrake is a video encoder - I don't believe there is anyway to passthough the video. If you want to keep the original video source - then some options below - 1. use mkvmerge to copy the stream and merge in your new audio tracks - easiest way to do this is to use mkvtoolnix - and just add sources from different MKV's, keeping the video track the same. 2. use ffmpeg with a -c:v copy
pwhodges 2023 Posted June 15, 2023 Posted June 15, 2023 (edited) HandBrake has no facility for video passthrough; it also is not a front-end for ffmpeg CLI. Explanation and summary here. Paul Edited June 15, 2023 by pwhodges
