QAQrz 6 Posted June 9, 2023 Posted June 9, 2023 All logs here 2023-06-09 15:51:17.598 Debug Server: http/2 Response 304 to host8. Time: 0ms. GET https://host1:8920/web/manifest.json 2023-06-09 15:51:17.637 Debug Server: http/2 Response 200 to host8. Time: 40ms. GET https://host1:8920/web/favicon.ico 2023-06-09 15:51:17.648 Error Server: Access token is invalid or expired. 2023-06-09 15:51:18.038 Debug Server: http/2 GET https://host1:8920/web/manifest.json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 2023-06-09 15:51:18.038 Debug Server: http/2 Response 304 to host8. Time: 0ms. GET https://host1:8920/web/manifest.json 2023-06-09 15:51:18.063 Error Server: Access token is invalid or expired. 2023-06-09 15:51:18.288 Debug Server: http/2 GET https://host1:8920/web/manifest.json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 2023-06-09 15:51:18.288 Debug Server: http/2 Response 304 to host8. Time: 0ms. GET https://host1:8920/web/manifest.json 2023-06-09 15:51:18.314 Error Server: Access token is invalid or expired.
QAQrz 6 Posted June 9, 2023 Author Posted June 9, 2023 Synology: DS920+ DSM version: 7.2-64570 emby version: emby-server-synology72_4.8.0.39_x86_64.spk
QAQrz 6 Posted June 11, 2023 Author Posted June 11, 2023 On 6/9/2023 at 7:20 PM, Luke said: Complete log file? here embyserver.txt
Carlo 4561 Posted June 11, 2023 Posted June 11, 2023 Hi, This log shows a lot of startup activity and then about 12 seconds of the interface being up. It did however show Theater logged in and then accessed the logs. 2023-06-12 01:12:03.137 Debug Server: http/1.1 GET http://host1:8096/emby/System/Configuration?X-Emby-Client=Emby Theater&X-Emby-Device-Name=QAQrz&X-Emby-Device-Id=QAQrz&X-Emby-Client-Version=3.0.20-1.5&X-Emby-Token=x_secret1_x. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/3.0.20-1.5 Chrome/100.0.4896.160 Electron/18.3.15 Safari/537.36 2023-06-12 01:12:03.139 Debug Server: http/1.1 GET http://host1:8096/emby/System/Logs/Query?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate,CommunityRating,OfficialRating,CriticRating&StartIndex=0&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Limit=30&X-Emby-Client=Emby Theater&X-Emby-Device-Name=QAQrz&X-Emby-Device-Id=QAQrz&X-Emby-Client-Version=3.0.20-1.5&X-Emby-Token=x_secret1_x. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/3.0.20-1.5 Chrome/100.0.4896.160 Electron/18.3.15 Safari/537.36 You can turn off Debug logging for general use. It tends to log a lot more then is normally needed making the logs harder to read then needed. We'll let you know if additional info is needed that only Debug logging will supply, otherwise just keep it off as it takes less resources and saves lots of space in the logs. So the web interface is up and your partial logs show that as well. I did however see "Access token is invalid or expired" from at least one client. If you are having trouble logging in on a specific client you may need to exit out of the app and try again. Carlo
QAQrz 6 Posted June 12, 2023 Author Posted June 12, 2023 Hello, the theater can be entered normally. I just downloaded the log from the theater, but I can’t enter the web interface in the browser, which corresponds to the error log at the bottom 5 hours ago, Carlo said: Hi, This log shows a lot of startup activity and then about 12 seconds of the interface being up. It did however show Theater logged in and then accessed the logs. 2023-06-12 01:12:03.137 Debug Server: http/1.1 GET http://host1:8096/emby/System/Configuration?X-Emby-Client=Emby Theater&X-Emby-Device-Name=QAQrz&X-Emby-Device-Id=QAQrz&X-Emby-Client-Version=3.0.20-1.5&X-Emby-Token=x_secret1_x. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/3.0.20-1.5 Chrome/100.0.4896.160 Electron/18.3.15 Safari/537.36 2023-06-12 01:12:03.139 Debug Server: http/1.1 GET http://host1:8096/emby/System/Logs/Query?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate,CommunityRating,OfficialRating,CriticRating&StartIndex=0&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Limit=30&X-Emby-Client=Emby Theater&X-Emby-Device-Name=QAQrz&X-Emby-Device-Id=QAQrz&X-Emby-Client-Version=3.0.20-1.5&X-Emby-Token=x_secret1_x. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/3.0.20-1.5 Chrome/100.0.4896.160 Electron/18.3.15 Safari/537.36 You can turn off Debug logging for general use. It tends to log a lot more then is normally needed making the logs harder to read then needed. We'll let you know if additional info is needed that only Debug logging will supply, otherwise just keep it off as it takes less resources and saves lots of space in the logs. So the web interface is up and your partial logs show that as well. I did however see "Access token is invalid or expired" from at least one client. If you are having trouble logging in on a specific client you may need to exit out of the app and try again. Carlo
Solution seanbuff 1356 Posted June 12, 2023 Solution Posted June 12, 2023 1 hour ago, QAQrz said: but I can’t enter the web interface in the browser, which corresponds to the error log at the bottom Hi, you have the Data Explorer plugin installed. Quote Info App: Loading Emby.DataExplorer, Version=4.8.0.26, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/var/plugins/Emby.DataExplorer.dll As per: https://emby.media/community/index.php?/topic/119194-update-to-48038-beta-unsuccessful/&do=findComment&comment=1257902 Please remove this plugin and restart your Emby Server - you should then be good to go.
Luke 42242 Posted June 13, 2023 Posted June 13, 2023 On 6/11/2023 at 11:35 PM, QAQrz said: tks. I'll give it a try. Hi, has this helped?
QAQrz 6 Posted June 14, 2023 Author Posted June 14, 2023 (edited) 5 hours ago, Luke said: Hi, has this helped? yeah, it works. Edited June 14, 2023 by QAQrz 1 1
