jjstecchino 8 Posted June 8, 2023 Posted June 8, 2023 (edited) After an automatic update to Emby server beta for windows v 4.8.0.29 I am unable to access the web interface. It loads to the black page with the emby logo and it is stuck there. If I inspect on the developer console I get an unauthorized error when loading itemcontextmenu.js Of note I can access the server from the Roku and embed theater without issues. The server seem to be working ok except for the web interface. As I can not access the GUI I cannot get anonymized logs. If needed I can pm them. I looked at them and I see no errors but some of these: 2023-06-07 21:06:41.430 Error Server: Access token is invalid or expired. Everything was working ok last week. I believe the server was autoupdated to the new version a few days ago Tied Safari, Chrome and edge. Tried to clear the cache on all 3 browsers Thanks for any assistance Edited June 8, 2023 by jjstecchino
Solution seanbuff 1353 Posted June 8, 2023 Solution Posted June 8, 2023 5 minutes ago, jjstecchino said: Everything was working ok last week. I believe the server was autoupdated to the new version a few days ago Do you happen to have the 'Data Explorer' plugin installed? If so, try removing it and restarting.
jjstecchino 8 Posted June 8, 2023 Author Posted June 8, 2023 2 minutes ago, seanbuff said: Do you happen to have the 'Data Explorer' plugin installed? If so, try removing it and restarting. Yep! That was it. Removed and now all good. Thanks so much. 1
