KandyMan 7 Posted June 7, 2023 Posted June 7, 2023 I was using my iPad to watch emby remotely and found that a particular movie would freeze in the same spot. It appears to be a transcoding issue as when turning off subtitles the movie played fine, however the subtitles were appearing when the language was not English so I've no idea what was happening at that part of the movie. I checked on my iPhone when I got home and found the issue was not present even with the subtitle track enabled. I've attached the log as I'm not sure if it's something on my end or on the server (Synology DS920+ DSM 6.2.4-25556 Update 7, 4.8.0.34 beta) ffmpeg-transcode-a5f00061-5b14-48a6-9858-8753a0009433_1.txt
Luke 42241 Posted June 7, 2023 Posted June 7, 2023 Hi, please attach the main Emby server log as well. Thanks.
KandyMan 7 Posted June 8, 2023 Author Posted June 8, 2023 My bad, forgot that one, attached below embyserver-63821779200.txt
KandyMan 7 Posted June 15, 2023 Author Posted June 15, 2023 Did anything noteworthy come from the logs?
Luke 42241 Posted June 28, 2023 Posted June 28, 2023 HI, can you try Emby for iOS 2.2.9 and let us know how that compares? Thanks.
