peter2020 2 Posted June 28, 2023 Posted June 28, 2023 Same here. iOS App Version 2.2.9 and server Version 4.7.13.0. LiveTV still the spinning circle, tuner starts and play stream, but Emby is not showing the stream. I can also try to catch log files later when at home.
Luke 42241 Posted June 28, 2023 Posted June 28, 2023 Can we please see new server log examples? Thanks.
peter2020 2 Posted June 29, 2023 Posted June 29, 2023 6 hours ago, Luke said: Can we please see new server log examples? Thanks. @LukePlease find attached the log part when starting a stream. embyserver.txt
peter2020 2 Posted June 29, 2023 Posted June 29, 2023 and here is a complete log from fresh server start and try to start a stream embyserver2.txt
mariadelmar 0 Posted June 29, 2023 Posted June 29, 2023 (edited) 15 hours ago, peter2020 said: Same here. iOS App Version 2.2.9 and server Version 4.7.13.0. LiveTV still the spinning circle, tuner starts and play stream, but Emby is not showing the stream. I can also try to catch log files later when at home. I have the same problem as you, iOS App Version 2.2.9 and server version 4.7.13.0. In case it has anything to do with it, which I think it does, I have iOS 16.5.1 installed on my iPhone. PS: I forgot to point out that on an Android phone, it works fine. Edited June 29, 2023 by mariadelmar
Fixodent66 4 Posted June 29, 2023 Posted June 29, 2023 I too am on ios 16.5.1, I wonder if this broke the emby Live Tv
learnbyflying 4 Posted June 29, 2023 Author Posted June 29, 2023 Just as a data point, iOS 15.7.7 (Original air 2) and iOS 16.5.1 are not working with live TV. Neither are pulling a tuner. I can grab logs if needed if the above it not enough.
Luke 42241 Posted June 29, 2023 Posted June 29, 2023 2 hours ago, learnbyflying said: Just as a data point, iOS 15.7.7 (Original air 2) and iOS 16.5.1 are not working with live TV. Neither are pulling a tuner. I can grab logs if needed if the above it not enough. Hi, yes that would be helpful. Thanks.
learnbyflying 4 Posted June 29, 2023 Author Posted June 29, 2023 @LukeLogs are attached, I turned debug mode on. I have three iOS device, iPad 9 (iOS 16.5.1, Emby 2.2.9), iPhone 14 Pro (iOS 16.5.1, Emby 2.2.9) and an iPad Air 2 (iOS 15.7.7, Emby 2.2.9) and I tried three different TV channels from each device. From the iPad 9 I tried WEATHHD 1102 (HDHR source), iPhone I tried FBNHD (MU3 from Channels DVR), and then the iPad Air 2 NGCHD 6070. Each time I just get the spinning wheel and the content fails to load. I was also watching the Server Manager screen and I don't see "X user is watching Y content". I then used my laptop and was able to successfully launch all three channels from the web player and the server manager sees me watching the content. I've attached all logs since the restart and ending emby server log from the previous restart so that I could provide clean logs. Recordings are not affected, I've tried accessing TV from a VPN IP and nothing changes the behavior. Please let me know if there is anything else I can provide. embyserver.txt embyserver-63823631707.txt ffmpeg-directstream-3240ea85-717c-4ecf-8e74-28c7ac72c351_1.txt ffmpeg-directstream-36346d51-7a0b-425c-a86d-fdce97915400_1.txt ffmpeg-remux-166d7c6b-9c34-4fd5-a815-9183e99ac997_1.txt hardware_detection-63823631725.txt
alfalfa6945 0 Posted June 30, 2023 Posted June 30, 2023 Just to add in to the IOS version conversation, 15.7.6 has the same issue everyone is talking about - live tv is not working on the app (v2.2.9)
cassete 11 Posted June 30, 2023 Posted June 30, 2023 (edited) Olá. Estou querendo saber como eu configuro meu receptor digital Sky ao emby live TV. Alguém pode me ajudar por favor. Brazil. Edited June 30, 2023 by cassete
sfatula 208 Posted July 1, 2023 Posted July 1, 2023 (edited) IOS 2.2.9 and emby server 4.7.13 is not working for me either. Edited July 1, 2023 by sfatula
PrincessClevage 175 Posted July 1, 2023 Posted July 1, 2023 I have same issue, tried two iPhone and one ipad all can not play live tv but can cast live tv to other devices. I also tried safari on these iOS devices and it also could not play livetv
Solution Luke 42241 Posted July 4, 2023 Solution Posted July 4, 2023 Hi, we've submitted an update to the apple store to resolve this. Thanks. 1
PaulW08 2 Posted July 4, 2023 Posted July 4, 2023 @Lukecan confirm 2.2.10 resolves this issue. Thanks so much!
peter2020 2 Posted July 4, 2023 Posted July 4, 2023 2 hours ago, Luke said: Hi, we've submitted an update to the apple store to resolve this. Thanks. @Luke i can confirm. With 2.2.10 live tv is working again with iOS. thanks a lot for fixing 1
Spaceboy 2573 Posted July 4, 2023 Posted July 4, 2023 yep working here too. and is this the first release with rotating video? thats a great addition
Luke 42241 Posted July 4, 2023 Posted July 4, 2023 26 minutes ago, Spaceboy said: yep working here too. and is this the first release with rotating video? thats a great addition Yes but it doesn’t have the new option yet to control the behavior.
Anielarias 25 Posted July 4, 2023 Posted July 4, 2023 1 hour ago, Luke said: Yes but it doesn’t have the new option yet to control the behavior. i have noticed in the past where it would auto rotate (which i personally dont like). so please do add an option to enable or disable this behavior.
learnbyflying 4 Posted July 4, 2023 Author Posted July 4, 2023 5 hours ago, Luke said: Hi, we've submitted an update to the apple store to resolve this. Thanks. Can confirm this is working as intended again, excellent work! TV is playing both from HDHR and from m3u sources, tuners are releasing as normal.
