dalezjc 14 Posted June 5, 2023 Posted June 5, 2023 Is there a way to customize the Home Page (save for the settings you can make from the settings page)? For example, change the "My Media" title to "Dale's Media"? I can see the css files, but not sure how they're being included in the index.html page. Thanks, Dale
ebr 16307 Posted June 5, 2023 Posted June 5, 2023 Hi, no there is currently no way to make that particular change.
GrimReaper 4845 Posted June 5, 2023 Posted June 5, 2023 38 minutes ago, dalezjc said: Is there a way to customize the Home Page (save for the settings you can make from the settings page)? For example, change the "My Media" title to "Dale's Media"? For local Web app only, custom CSS (Home Screen section dependent):
dalezjc 14 Posted June 5, 2023 Author Posted June 5, 2023 10 minutes ago, GrimReaper said: For local Web app only, custom CSS (Home Screen section dependent): Thanks! I did a search but this didn't come up. Dale
dalezjc 14 Posted June 5, 2023 Author Posted June 5, 2023 Okay, so what css file do I need to edit to put the css in?
arrbee99 1834 Posted June 5, 2023 Posted June 5, 2023 You just go to the server Dashboard, Settings tab and copy and paste into the Custom CSS box. Remember to Save and refresh the page.
dalezjc 14 Posted June 5, 2023 Author Posted June 5, 2023 Yeah, that didn't work. No problem though. I'll wait for the next major upgrade.
arrbee99 1834 Posted June 5, 2023 Posted June 5, 2023 Works for me on the latest beta if you change where it says section1 to section0. There's two to change.
dalezjc 14 Posted June 6, 2023 Author Posted June 6, 2023 2 hours ago, arrbee99 said: Works for me on the latest beta if you change where it says section1 to section0. There's two to change. That did it! Thanks much!
arrbee99 1834 Posted June 6, 2023 Posted June 6, 2023 Jolly good. Don't forget there's some other nice bits to use in the css subforum if interested.
dalezjc 14 Posted June 6, 2023 Author Posted June 6, 2023 9 hours ago, arrbee99 said: Jolly good. Don't forget there's some other nice bits to use in the css subforum if interested. Awesome! I'll take a look there.
