Luke 42289 Posted September 3, 2023 Posted September 3, 2023 Where are you looking for the option to select original quality in the client? It is there.
TeraMan 4 Posted September 3, 2023 Author Posted September 3, 2023 with a user it does not give the option of original quality, The original option is only given by the user who has the server
Luke 42289 Posted September 3, 2023 Posted September 3, 2023 12 minutes ago, TeraMan said: with a user it does not give the option of original quality, The original option is only given by the user who has the server What do you mean by user who has the server?
TeraMan 4 Posted September 3, 2023 Author Posted September 3, 2023 I mean the user of the server account, the main account
Luke 42289 Posted September 3, 2023 Posted September 3, 2023 What’s the difference between the users?
TeraMan 4 Posted September 3, 2023 Author Posted September 3, 2023 with the server user it gives the original quality option, but with the other users, It only gives the option to download, without being able to select quality. I don't know how to explain it anymore
Luke 42289 Posted September 14, 2023 Posted September 14, 2023 On 9/3/2023 at 3:07 PM, TeraMan said: with the server user it gives the original quality option, but with the other users, It only gives the option to download, without being able to select quality. Can you show a screenshot of what you do see?
TeraMan 4 Posted September 16, 2023 Author Posted September 16, 2023 Image from server user Image from the user
GrimReaper 4926 Posted September 16, 2023 Posted September 16, 2023 Does that other user have Allow transcoded downloads enabled in user settings?
TeraMan 4 Posted September 16, 2023 Author Posted September 16, 2023 10 minutes ago, GrimReaper said: Does that other user have Allow transcoded downloads enabled in user settings? This was it, thank you very much. That was the problem, I had that option disabled. 2
