sums2001 1 Posted June 4, 2023 Posted June 4, 2023 HDR tone mapping is not working properly when transcoding is enabled.I tested several moive with 4k hdr10 both with Jellyfin.Emby will automatically select the hablel mode when using hardware transcoding at a low bit rate. After transcoding, the color tone of the video image is pale, and the color tone is normal when playing without transcoding. Jellyfin uses BT.2390, and the color display is normal when working in normal mode or low bit rate transcoding.How can I solve this problem?
GrimReaper 4845 Posted June 4, 2023 Posted June 4, 2023 Install Diagnostics plugin where you can select desired tonemapping algorithm under Advanced transcoding settings.
sums2001 1 Posted June 4, 2023 Author Posted June 4, 2023 41 minutes ago, GrimReaper said: Install Diagnostics plugin where you can select desired tonemapping algorithm under Advanced transcoding settings. I have installed the diagnostic plug-in, and tried 3 modes in the settings, none of which can achieve satisfactory output effects, can you provide BT.2390 mode?
sums2001 1 Posted June 4, 2023 Author Posted June 4, 2023 BT.2390 mode was found in Software Tone Mapping, but setting Software Tone Mapping alone tone mapping does not work.
Luke 42185 Posted June 4, 2023 Posted June 4, 2023 6 hours ago, sums2001 said: BT.2390 mode was found in Software Tone Mapping, but setting Software Tone Mapping alone tone mapping does not work. Hi, why do you think it doesn’t work?
sums2001 1 Posted June 7, 2023 Author Posted June 7, 2023 On 6/4/2023 at 11:48 PM, Luke said: Hi, why do you think it doesn’t work? The performance of the screen has not improved, and there is no prompt in the information displayed by the diagnostic tool to enable BT.2390.
visproduction 328 Posted June 9, 2023 Posted June 9, 2023 Adobe editor blogger info about HDR conversions using online editor. He apparently has fine tuned the HDR conversion with custom .lut files. Perhaps this can be useful in fine tuning conversion with Emby. https://www.youtube.com/watch?v=cIgnyx5KXQM
sums2001 1 Posted June 12, 2023 Author Posted June 12, 2023 Thank you very much, the content you mentioned is for mobile phones.
Luke 42185 Posted June 13, 2023 Posted June 13, 2023 @sums2001 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
