TonioRoffo 4 Posted June 4, 2023 Posted June 4, 2023 (edited) Setup: Ubuntu server running 4.7.13.0 (same issue with 4.7.12.0) Client is Emby for android TV 2.0.80g registered Hardwired gigabit network between server and client Issue: Playback of 4K HDR content buffers, was not the case in servers <=4.7.12.0 Server indicates "Reducing bitrate due to quality setting" and is transcoding. My rig can't handle transcoding. Expect: No transcoding, direct playback Tested: Forcing Max Streaming Bitrate in the client, Auto or maximum speed settings -> no change Set client connecting to http instead of https -> no change Basically all my HDR playback is broken at this moment. Please help me which log files to send to fix this issue Thanks Edited June 4, 2023 by TonioRoffo
TonioRoffo 4 Posted June 4, 2023 Author Posted June 4, 2023 Only current workaround to watch stuff is disabling video transcoding in the user settings.
GrimReaper 4845 Posted June 4, 2023 Posted June 4, 2023 1 hour ago, TonioRoffo said: Please help me which log files to send to fix this issue Post ffmpeg log(s) created. 1 hour ago, TonioRoffo said: Server indicates "Reducing bitrate due to quality setting" 1 hour ago, TonioRoffo said: Forcing Max Streaming Bitrate in the client, Auto or maximum speed settings -> no change Where did you set that, client settings or OSD cog menu?
TonioRoffo 4 Posted June 6, 2023 Author Posted June 6, 2023 Very sorry; work days are long & hard. I'll get back to with ffmpeg you as soon as possible. The forcing of the max streaming bitrate, I've tried in the client itself.
TonioRoffo 4 Posted June 9, 2023 Author Posted June 9, 2023 Hello, so you need me to playback a file which is faulty, and then provide you the latest ffmpeg log from the Emby Server? Thanks
GrimReaper 4845 Posted June 9, 2023 Posted June 9, 2023 1 minute ago, TonioRoffo said: Hello, so you need me to playback a file which is faulty, and then provide you the latest ffmpeg log from the Emby Server? Thanks Yes, as bitrate limit can be imposed in three places: server-side global or per-user limit and/or client-side quality setting; selecting Max quality in client app will not override any of the other two.
TonioRoffo 4 Posted June 9, 2023 Author Posted June 9, 2023 I was able to recover a log from my backups, please find it included. * User internet streaming bitrate is limited at 8Mbps (but my playback device used was local LAN) * I have disabled "Allow video transcoding, if necessary, during media playback" to work around the issue. * Under serve/network, my internet streaming bitrate limit was 8Mbps, I've put it to 25 and higher just to see if it had an effect. It doesn't. ffmpeg-transcode-2b068e97-505c-4683-b240-b4e71b265cff_1.txt
TonioRoffo 4 Posted June 9, 2023 Author Posted June 9, 2023 OK, so strangely: "TranscodeReasons=ContainerBitrateExceedsLimit"... is in the log file. However I'm playing this back on LAN, then the limits shouldn't apply, right?
GrimReaper 4845 Posted June 9, 2023 Posted June 9, 2023 Quote >>>>>> User policy for Emby Enable Playback Remuxing: True Enable Video Playback Transcoding: True Enable Audio Playback Transcoding: True User Remote Bitrate Limit: 8,000,000 bps Global Remote Bitrate Limit: 20,000,000 bps Do you have any particular LAN network specified in your Settings>Networks tab so your 192.x subnet gets interpreted as remote? Quote App: AndroidTv 2.0.80g SHIELD Also, you might wanna update your client app to latest stable (.83) or beta (.87).
TonioRoffo 4 Posted June 9, 2023 Author Posted June 9, 2023 Thank you, GrimReaper: * Client was upgraded to .87 and same problem (see above) - the log file is from earlier. * 192.168.1.0/24 is indeed my LAN. * Server/network/LAN networks is set to: 192.168.1.0/255.255.255.0 (is correct) * Local IP address is set to 192.168.1.14 (this was blank, no change with the set IP)
TonioRoffo 4 Posted June 9, 2023 Author Posted June 9, 2023 (edited) @GrimReaper- I've found something in my embyserver log files: Quote "2023-06-09 09:55:46.677 Error NetworkManager: Invalid lan networks setting: 192.168.1.0/255.255.255.0" Perhaps this is causing the problem? Did the format change, as this setting was in my Emby config for years. Edit: Changed it to 192.168.1.0/24, no more error in the log. I'll investigate later if this fixes the problem. The former format should be correct as Emby states: Quote Comma separated list of IP addresses or >>>IP/netmask entries<<< for networks that will be considered on local network when enforcing bandwidth restrictions. Edited June 9, 2023 by TonioRoffo
Solution GrimReaper 4845 Posted June 9, 2023 Solution Posted June 9, 2023 (edited) 6 minutes ago, TonioRoffo said: @GrimReaper- I've found something in my embyserver log files: Perhaps this is causing the problem? Did the format change, as this setting was in my Emby config for years. It likely does, as if it's not recognized as local - it's been considered remote then. As for format, you can try with 192.168.1.0/24, see what gives? Edited June 9, 2023 by GrimReaper
Q-Droid 1002 Posted June 9, 2023 Posted June 9, 2023 Should the verbiage for this section in the network settings be updated to make it clear that it expects CIDR notation? I've seen this type of issue come up before.
pwhodges 2023 Posted June 9, 2023 Posted June 9, 2023 The description as given is simply wrong - CIDR notation defines a netmask but is not itself a netmask. Paul
Luke 42185 Posted June 13, 2023 Posted June 13, 2023 Quote As for format, you can try with 192.168.1.0/24, see what gives? @TonioRoffodid you try this? It should resolve your issue. Thanks.
TonioRoffo 4 Posted June 15, 2023 Author Posted June 15, 2023 Hello, the issue is resolved by entering the subnet as 192.168.1.0/24. However, 192.168.1.0/255.255.255.0 format worked until 2 versions of Emby ago. I'd humbly suggest to edit the inline help or see this as a bug. Thanks for all the help!
Luke 42185 Posted June 15, 2023 Posted June 15, 2023 Hi, yes we’ll be restoring support for that. Thanks. 1
