tomadick 8 Posted June 1, 2023 Posted June 1, 2023 Hello, for me the automatic and manual channel assignments for live TV have disappeared! What could be the reason for this? In addition, the automatic channel assignment no longer seems to work, I have removed all sources and added again after a server restart. Is it possible to start the automatic channel assignment manually? Version 4.8.0.37 beta
Luke 42242 Posted June 1, 2023 Posted June 1, 2023 Hi, disappeared from where? Quote the automatic channel assignment no longer seems to work, Why do you think it doesn't work? Example?
tomadick 8 Posted June 1, 2023 Author Posted June 1, 2023 2 hours ago, Luke said: Hi, disappeared from where? Why do you think it doesn't work? Example? I had assigned about 175 entries manually, almost 250 were assigned automatically. No more assignment exists. And I think that the automatic assignment no longer works, because I still have no stations - except 1 manual assignments - associated with entries in the EPG.
