Luke 42237 Posted July 11, 2023 Posted July 11, 2023 2 minutes ago, nicko84 said: @LukeWhat about Vulkan API on ET for desktop Luke ? Is it in the road map ? We are following mpv and staying up to date with their developments.
Guest Posted July 11, 2023 Posted July 11, 2023 The vulkan api has always been present. It just needs to be implemented. --gpu-api=vulkan
SteveFintel 30 Posted July 12, 2023 Posted July 12, 2023 I implemented gpu-api=vulkan in the mpv.conf file. Not only did the refresh rate remain constant, but the desktop was not blacked out on 1920:803 content. FYI, the system is using 10th gen Intel CPU graphics connected to a Sony A9G monitor. I can play the same content on a Firestick 4K or the TV's Android TV OS and it plays in HDR at 24 FPS (like the source material).
nicko84 72 Posted July 12, 2023 Author Posted July 12, 2023 It seems that Vulkan is supported on mpv but not not for all hardware and/or drivers if i'm note wrong... https://github.com/mpv-player/mpv/issues/11739
Guest Posted July 12, 2023 Posted July 12, 2023 Theater is using the mpv library. I'm thinking that the gpu-api option might need to be written into the scripts/options. You have to remember that electron is also involved. Many are using these parameters in the standalone player. Also, the refresh rate switching is external to mpv. It's an executable written specially for Theater by the Emby developers.
SteveFintel 30 Posted July 12, 2023 Posted July 12, 2023 I'm really trying to get to refresh rate switching which is non-functional with Emby Theater on my platform. How can I make that happen? Note that Kodi does this flawlessly on the same hardware.
Guest Posted July 12, 2023 Posted July 12, 2023 2 minutes ago, SteveFintel said: I'm really trying to get to refresh rate switching which is non-functional with Emby Theater on my platform. How can I make that happen? Note that Kodi does this flawlessly on the same hardware. Are you saying that refreshrate switching doesn't work at all, no matter which settings you use?
SteveFintel 30 Posted July 12, 2023 Posted July 12, 2023 (edited) That's correct. On rare occasions, it will switch, but there's no audio. Those rare occasions are not repeatable. I've tried real hard. Should we start another thread? Edited July 12, 2023 by SteveFintel
Guest Posted July 12, 2023 Posted July 12, 2023 Just now, SteveFintel said: That's correct. On rare occasions, it will switch, but there's no audio. Those rare occasions are not repeatable. I've tried real hard. OK, so that needs specific attention. Start an new thread. Clear your mpv.conf, set the Theater settings to auto except video output should be gpu-next. Create an mpv log while the issue is happening and attach it. Luke will need to see what's happening.
Guest Posted July 12, 2023 Posted July 12, 2023 1 hour ago, nicko84 said: It seems that Vulkan is supported on mpv but not not for all hardware and/or drivers if i'm note wrong... https://github.com/mpv-player/mpv/issues/11739 Remember that is referring to using vulkan for everything, and not just using the gpu-api.
