nt-it-team 6 Posted May 30, 2023 Posted May 30, 2023 We are looking at purchasing a TECH5-16DT-4X4 for the UK market. I have a question on tuner allocation. It seems it has 4 NICs on the rear, I want to check how the tuners would be allocated. Once the first tuner is full with 4 viewers, will it automatically use the next tuner (5th tuner) on the same IP address, or will this need to send the stream to the next NICs IP address. How would Emby handle this with the xml feed? Any ideas? Ultimately, I need more than 4 tuners!
Luke 42242 Posted June 3, 2023 Posted June 3, 2023 HI, the server will automatically use the next tuner, but i'm not sure if it will be on the same ip address or not. I think that is all managed internally by the hd homerun.
