Lyfesaver 135 Posted May 30, 2023 Posted May 30, 2023 So, from another post I read (or misread) that Auto organize will rename files, but will take known metadata and use it in a filename? For instance, let's say I have the public domain Grant/Hepburn movie, "Charade" and it's filename was: Charade (1963) but I wanted it renamed: Charade (1963) BluRay-1080p Is something like this currently doable?
Luke 42255 Posted May 30, 2023 Posted May 30, 2023 Hi, I don't know that it will retain the bluray/1080p moniker. It's possible that a community contributor may have added that feature (I don't recall), but that's not how it was originally built way back when.
Junglejim 385 Posted May 31, 2023 Posted May 31, 2023 15 hours ago, Lyfesaver said: So, from another post I read (or misread) that Auto organize will rename files, but will take known metadata and use it in a filename? For instance, let's say I have the public domain Grant/Hepburn movie, "Charade" and it's filename was: Charade (1963) but I wanted it renamed: Charade (1963) BluRay-1080p Is something like this currently doable? I don't think so, at least with the standard catalog version. It will usually strip that info and rename it how you have it already. I'm not sure what "Original File Name %fn" does I've never tested it... I know @chefwas working on a more advanced version, maybe ask there... https://emby.media/community/index.php?/topic/109245-auto-organize-plus-public-beta/ 2
