bjhille 3 Posted May 29, 2023 Posted May 29, 2023 I used to love the series "V". So, I have a copy of three series: * V - The Complete Series (1984) - 19 episodes. - loads perfectly * V - The Final Battle (1984) - 3 part mini-series - I feed it "tt0086823" to identify the show and pick the correct show, but it loads the complete series (tt0086822) * V - The original Mini-Series (1983) - feed it "tt0085106" to identify the show, but it loads 2009 (tt1307824) How do I get Emby to identify the correct version of "V"? Thanks Brian.
Gilgamesh_48 1243 Posted May 29, 2023 Posted May 29, 2023 (edited) I just name the main directories quite simply: V (2009) V (1984) For the directory names and inside those the seasons are just named normally. For the extras and original mini-series I use "Season 0" and name/number them exactly as The TVDB has them. I have had no problem. Things like "The final battle" are just another special. I never needed to actually use the fancy matching of id identifiers. But remember my matching was done years ago and things have changed a LOT since then. Edited May 29, 2023 by Gilgamesh_48 addition
GrimReaper 4845 Posted May 29, 2023 Posted May 29, 2023 4 hours ago, bjhille said: I used to love the series "V". So, I have a copy of three series: * V - The Complete Series (1984) - 19 episodes. - loads perfectly * V - The Final Battle (1984) - 3 part mini-series - I feed it "tt0086823" to identify the show and pick the correct show, but it loads the complete series (tt0086822) * V - The original Mini-Series (1983) - feed it "tt0085106" to identify the show, but it loads 2009 (tt1307824) How do I get Emby to identify the correct version of "V"? Thanks Brian. Assuming you have TVDB as your TV Shows library top-preferred provider: you can't, as TVDB lists both The Original Mini-Series (1983) and The Final Battle (1984) as Specials 1-5 for The Complete Series (1984). https://thetvdb.com/series/v/seasons/official/0 TMDB does, though, so you have few ways to tackle this: 1) Put TMDB on top of your preferred meta-providers list; name series folders as: V - The Original Miniseries (1983) [tmdbid=14141] V - The Final Battle (1984) [tmdbid=75896] V (1984) [tmdbid=75893] Scan media library. Lock the items once scraped, revert TVDB on top afterwards. 2) Reorganize your folder structure putting both The Original Miniseries and The Final Battle episodes as Season 0 Episodes 1 through 5 of The Complete Series. 3) Add those shows separately on TVDB yourself (though don't know whether Moderators will allow that/is it in line with TVDB guidelines). 1 1
bjhille 3 Posted May 29, 2023 Author Posted May 29, 2023 Thanks guys..didn't realize they were "specials". I reorganized them with the Season 0 Episodes 1-5 and it works how I expected. Thanks for the help! 1
