katbyte 41 Posted May 28, 2023 Posted May 28, 2023 I tried to update to treafik v3 today and it seemed to break the iOS, tvOS and OSX applications in that no matter the show i would get "no compatible streams". infuse TV on the apple tv also stopped working. however streaming from safari/chrome & the android TV app worked just fine. reverting to treafik 2.9.8 with no other change and the iOS/tvOS applications started working again (on latest beta) embyserver.txt
Luke 42245 Posted May 28, 2023 Posted May 28, 2023 HI, it's hard to say. Does traefik have any logs that might shed some light on what it's doing?
Luke 42245 Posted May 28, 2023 Posted May 28, 2023 Also, did you go through this? https://doc.traefik.io/traefik/master/migration/v2-to-v3/
katbyte 41 Posted July 16, 2023 Author Posted July 16, 2023 (edited) sorry i didn't get the notifications for your reply @Luke i just tried this again and simply upgrading to v3 still breaks emby i did follow the guide and there is nothing in the logs indication any problems same issue: breaks ios/tvos/osx apps, andriod tv works... sorta, chrome/safari seem fine Edited July 16, 2023 by katbyte
Luke 42245 Posted July 17, 2023 Posted July 17, 2023 On 7/16/2023 at 1:27 AM, katbyte said: sorry i didn't get the notifications for your reply @Luke i just tried this again and simply upgrading to v3 still breaks emby i did follow the guide and there is nothing in the logs indication any problems same issue: breaks ios/tvos/osx apps, andriod tv works... sorta, chrome/safari seem fine Did you see this?
katbyte 41 Posted July 20, 2023 Author Posted July 20, 2023 no but my config doesn't seem materially different and my issue is with ios clients. andriod tv basically works fine (and everything works fine with treafik v2)
Luke 42245 Posted July 20, 2023 Posted July 20, 2023 16 hours ago, katbyte said: no but my config doesn't seem materially different and my issue is with ios clients. andriod tv basically works fine (and everything works fine with treafik v2) Did you try what that user tried that helped resolve it?
katbyte 41 Posted July 31, 2023 Author Posted July 31, 2023 no as my config basically matched the working one posted and i am not using SSO middleware like the config with issues seems to be
katbyte 41 Posted October 14, 2023 Author Posted October 14, 2023 (edited) No, thatVM only runs emby so i have just left it on treafik 2.x. let me try again .. it is still an issue andriod + web works fine. ios/apple tv/macbook emby app all get no compatible streams (or crash) @Luke Edited October 14, 2023 by katbyte
