I've added some episodes of Looney tunes and organised in the same theTVDB has it. Emby scraped the wrong show and when I use the correct tbdb ID to identify, it says "no items matching your search were found". It also doesn't find the show when searching by name.
Here's the TVDB entry: https://thetvdb.com/series/looney-tunes
What's the problem?
Edit: I've disabled all metadata downloaders for the TV library except thetvdb and now it cannot find any TV show...has the API been broken or what ?
Edit2: Had to rebuild the whole docker container to get it working again...It will now find Looney Tunes on TV DB but when clicking "Okay" after selecting the correct show, it doesn't do anything..
Edited by joncy92
Deathsquirrel
What's the file naming convention, directory structure, and library type?
