TCEmby1 8 Posted May 26, 2023 Posted May 26, 2023 As directed in the fix for this problem, I've deleted the recommended files but I don't understand the Hosts file fix that says: Add an entry to your server machine etc/hosts file: emmm.spxaebjhxtmddsri.xyz 127.0.0.1 This is the host name of the control server which the malware is communicating with Do I just add emmm.spxaebjhxtmddsri.xyz 127.0.0.1 at the last line in my hosts file?
Solution Q-Droid 1011 Posted May 26, 2023 Solution Posted May 26, 2023 The hosts file format is [IP address] [hostname] [alias]. While the instruction is to add a line for the the domain it is not good practice to have multiple entries with the same IP. What you should add/edit instead for the localhost entry is: 127.0.0.1 localhost emmm.spxaebjhxtmddsri.xyz This ensures that reverse lookups (gethostbyaddr) return the correct hostname while forward lookups on the domain still return the desired IP.
