Xorp 48 Posted May 25, 2023 Posted May 25, 2023 Embedded track titles are not displaying from the audio and subtitle options menu on, instead of the custom track title like "Commentary with director and actors" it shows just the codec name "AC3 Stereo" As of version 2.0.87g. Not sure what version the regression happened, but I believe it was recent.
Luke 42244 Posted May 25, 2023 Posted May 25, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Xorp 48 Posted December 3, 2023 Author Posted December 3, 2023 6+ months later, still not fixed. For an example of what's broken. Emby: Plex:
Xorp 48 Posted December 3, 2023 Author Posted December 3, 2023 Also, this is not the first time this regression has happened: This is getting tiresome this basic issue keeps coming back.
Xorp 48 Posted December 3, 2023 Author Posted December 3, 2023 This feature was in the AndroidTV version for many years, can it return?
Luke 42244 Posted December 3, 2023 Posted December 3, 2023 43 minutes ago, Xorp said: This feature was in the AndroidTV version for many years, can it return? @Xorp Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
rbjtech 5344 Posted December 10, 2023 Posted December 10, 2023 On 03/12/2023 at 17:59, Xorp said: This feature was in the AndroidTV version for many years, can it return? AndroidTV has always had this function - it has not been removed. Check your AndroidTV configuration using the settings menu - you may have turned it off. Also check the server configuration. You do not need the Android (nonTV) version to see the embedded titles ...
